Supercharger Pulley Bearing
Old Nov 27, 2010 | 05:39 PM
FiftyThree033's Avatar
Default Supercharger Pulley Bearing
I had a little quiet time today, so I pulled out my 3 volume Crossfire repair manual for a little informative reading.
A fellow forum member was kind enough to include a supercharger pulley bearing with the purchase of a new in the box SRT6 luggage set.
For the heck of it I thought would check out the bearing replacement procedure for down the road.
I could't find it anywhere in the manuals.
Am I not seeing it or is it not in the repair manuals?
Some input please!
BTW
If anyone should need a page or two scanned and emailed, I could do that for you.
Old Nov 27, 2010 | 06:10 PM
bmorgan's Avatar
Default Re: Supercharger Pulley Bearing
I checked the service manual, and it is not in there either... Just how to remove and install the pulley. You will need a bearing press to change them out.
Old Nov 27, 2010 | 06:48 PM
32krazy!'s Avatar
a word of caution!!! the bolt that holds the pulley on is hollow. you will break this bolt if you use more than 20 nm of torque. the cost of a replacement bolt is 1000$!!! you cant buy it separete. as bob said a press is needed to push out the bearing but be careful not to hurt the outside of the pulley
Old Nov 28, 2010 | 11:33 PM
satellite's Avatar
This is good (but scary) info! Was about to tackle this and glad I read this first.
Old Nov 29, 2010 | 01:02 PM
MikeR's Avatar
You could also replace the bolt with a matching size from your hardware or auto parts store.... but be sure to follow the factory torque spec.... you just wont have to worry about twisting it in half.... of course there are differing opinions on doing a replacement
If/when I have to replace the bearing on mine it will be get a new solid bolt....
Old Dec 10, 2010 | 09:44 PM
firemen's Avatar
How much do these Supercharger kits go for? In my repair manual they says that I need to remove the supercharger drive belt first before the crankshaft pulley. Does this correct?
Old Dec 10, 2010 | 09:51 PM
32krazy!'s Avatar
Originally Posted by firemen
How much do these Supercharger kits go for? In my auto repair manuals it says that I need to remove the supercharger drive belt first before the crankshaft pulley. Does this correct?
supercharger cost 7000$. you need to remove the sepentine belt if you want to access the crank pulley
Old Dec 11, 2010 | 02:49 AM
I know nothing about the supercharger but when they use a part that easily breaks it is generally for a reason. The reason is that this part fails before something more important fails. Just like shear pins in lawn mowers and snowblowers.
rmcdaniel12
Nov 4, 2015 04:08 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
Sep 26, 2015 10:21 PM
