Transmission Fluid
Sigh, I'm finally going to do my transmission service. I've been dreading this only because I know it can be a very messy job. Where can I find the best deal on Transmission fluid and is there a "recommended" cheaper alternative to the MB liquid platinum we have to put in there? 9 Quarts/Liters right?
You'll find all the info you need here.Mercedes-Benz 722.6 Transmission FAQ - Benzworld.org - Mercedes-Benz Discussion Forum
MB 236.10 sheet
MB 236.10 Flüssigkeitsgetriebeöl (ATF) A 001 989 21 03 Daimler AG
Mercedes-Benz Getriebeöl Blatt 236.10 Daimler AG
Shell ATF 3403-M 115
(So there is only one non-Mercedes fluid on this current list).
MB 236.12 sheet
Aral Getriebeol ATF M12
Fuchs Titan ATF 3353 Fuchs
MB 236.12 ATF 3353 A 001 989 45 03 Daimler AG
Mercedes-Benz Automatik-Getriebeöl Blatt 236.12 Daimler AG
Mobil ATF 3353
Shell ATF 3353
(So there are four non-Mercedes fluids on this current list).
MB 236.14 sheet
Fuchs TITAN ATF 4134
Fuchs TITAN EG ATF 134
MB 236.14 ATF NAG2VSport A 001 989 68 03 Daimler AG
Mercedes-Benz Automatik-Getriebeöl Blatt 236.14 Daimler AG
Mercedes-Benz Getriebeöl Blatt 236.14 Daimler AG
Mobil ATF 134
Shell ATF134
MB 236.12 sheet
Mobil ATF 3353
Shell ATF 3353
MB 236.14 sheet
Mobil ATF 134
Shell ATF134
Steve will tell you it's not his car, but to use OEM Benz.
As hard as you run yours, I could concur.
Just be sure to bring a shiny green drip pan.
I'll bring the jokes.
......9 Quarts/Liters right?
Just saying.
If you put in 9 quarts and it takes 9 liters then you have put in 1/2 liter too much. That 1/2 liter plus the fluid that stays in there means it's overfilled.
Just saying.
Just saying.
Oh I'm sorry. For some reason I seem to think that everyone will know exactly what I mean when I write something. How much does it take? 9 Quarts? Liters?
Then read Tighed1's post. https://www.crossfireforum.org/forum...tml#post455674
From the Shop manual.
Add the following initial quantity of Shell 3403 to transmission:
a. If only the fluid and filter were changed, add 5.0 L (10.6 pts.) of transmission fluid to the transmission.
b. If the transmission was completely overhauled, the torque converter was replaced or drained, and the cooler was flushed, add 7.7 L (16.3 pts.) of transmission fluid to the transmission.
Check the transmission fluid level. (Refer to 21 - TRANSMISSION/TRANSAXLE/AUTOMATIC NAG1/FLUID - STANDARD PROCEDURE), and adjust as required.
I just paid $20/ US quart (946 ml) for Mopar ATF at the Chrysler stealer in Niagara Falls NY. Part # 05127382AB. Label has MB-236.14 Crossfire/Sprinter printed on it. I'd be interested to know where it can be had at a better price?
When I did mione, this is what I found to be the best "cheap" alternative:
Shell 3353 is 236.12 certified. I bought a case at $9.26/qt. The container doesn't have any "generic" ATF statements. It specifically states: Meets MB 236.12 spec for use in MB 7-speed transmissions. Also for use in older 5-speed auto trans. Backwards-compatible with 236.10 fluid.
It appears this is the OEM fluid just not in MB packaging.
13dog its really not that messy, (unless you forget to put the magnet in the pan before you add 4 qts!). get 8 qts should be fine i have a qt or so extra
and john i will continue to teach you youngsters! green pan antifreeze black pan oil!!
Thats the fluid thats in our trannies and exactly what I bought for the leak fix but I paid $22 at dealer in GTA. Glad I only needed 1 Quart.
Steve,
Originally Posted by 32krazy!
and you would be WRONG!!
sprinter fluid in mine 2$ per qt cheaper than the m/b fluid. buggins choice would work cheaper still. but remember "it aint my car!"
MB now recommends 236.14 specification ATF in these transmissions.
current approvals-
MB 236.14 - Automatic transmission fluids (ATF, Specification 236.14) - Mercedes-Benz Specifications for Operating Fluids
Fuchs Titan 4134 meets 236.14 requirements. http://www.opieoils.co.uk/pdfs/New-F...N-ATF-4134.pdf
It’s relatively inexpensive from RM European.
current approvals-
We have GOT to do some more wrenching soon. I miss the laughs
