Balls Deep
Gor Gor big!!
wow, there is a better way, deflate both the race tires and inflate them at the track. they should both fit in the hatch. i do it with ours. basically stand the wheel up, sit on it, pull out the valve cover. when all the air is out and its ovaled then put the valve core back in. you will have 2 ovalled shaped wheels that can fit in the back and the hatch shuts. stick the jack and tool box to the side (still in the trunk), we even fit the helmets too!
Hey Rob If you can figure out a way to do that with a roadster I'll make you my most bestest Friend!!!
Colin, man haven't seen you on here in forever. Hope you are doing well...
...you should just lay a towel down on the front seat and put both tires up there. I have had to do that before when transporting more than two tires.
trying to get lower IATs. I don't think I'm getting enough airflow, even at highway speeds. SPAL 6.5" pusher fans, these babies rip...
tuna, let us know how that works for you.... I recall Woody trying several small fans on a LET HE and it didnt pan out... hope yours work for you....
What were your IAT's without them? With them?
Like 130 to 140 Les, but now temps are warmer outside and my average temp while cruizing is always 30 above outside temps. I don't get a lot of sustained high rpm driving like when you race however.
My IAT's run 20º over ambient but my H/E holds a gallon. It's almost always around 90º here so my IAT's run about 110º in the city. I'm still on the stock pump and sometimes think I should change it for more flow.
Les
Les
Didn't really make a difference
I can cool down my IAT real fast after parking, getting rid of the heat soak.
Would be good for waiting in line to drag race (Wed. night!) but that's about it. My IATs are always 25-30F above ambient. These fans are VERY loud!! Oh well, I only spent about $120 on the whole idea.
Originally Posted by 32krazy!
with my supercooler i run 90* below engine temp consistently and then it spikes on wot run then back down very quickly
Originally Posted by MikeR
That's too bad...
Good luck on Wed!
304 injectors.
I'm trying these phenolics, looks like they fit.
Also new "used" SC guts.
160 degreeF. thermostat I made.
And finally, I've never seen the SC rotors/screws before; what is the pinkish color it has? Is that the coating we've heard about that Methanol is purported to eat up? BTW, thanks for your advice on my reservoir tank mount, I finally installed it today.
