Can't Get into Car
Old Jan 25, 2011 | 09:13 AM
Marine05's Avatar
Default Can't Get into Car
Hello Everyone,
This morning when I went to get into my car, the door did not unlock. This past weekend, I had the car battery replaced and it started right up. I drove the car home, placed it in the garage and locked it. Question....Is the programming of the key fob lost since I replaced the battery or is something else going on? Any ideas how I can get into the car? It is a roadster.
Thanks,
Glenn AKA Marine05
Old Jan 25, 2011 | 09:22 AM
LantanaTX's Avatar
Default Re: Can't Get into Car
Something else of probably goind on. When was the last time you changed the battery in the fob?
Old Jan 25, 2011 | 09:56 AM
Originally Posted by Marine05
Hello Everyone,
This morning when I went to get into my car, the door did not unlock. This past weekend, I had the car battery replaced and it started right up. I drove the car home, placed it in the garage and locked it. Question....Is the programming of the key farb lost since I replaced the battery or is something else going on? Any ideas how I can get into the car? It is a roadster.
Thanks,
Glenn AKA Marine05
Use the key or a bayonet.
If it was a coupe you could use a key or the standard issue can opener.
Old Jan 25, 2011 | 09:57 AM
AlG's Avatar
AlG
Have you tried sticking the key in the door lock on the driver's side and turning? That should open it. I've had this happen to me as well, without changing the battery in the car. Once I got in, I put the key in the ignition, started the car and the fob must have relinked with the bcm and I never had the problem again. Matter of fact, it affected both of my fobs.
Old Jan 25, 2011 | 10:12 AM
Marine05's Avatar
Being a retired Marine I like the bayonet idea, but the frugal side of me is preventing me from doing it.
Old Jan 25, 2011 | 10:15 AM
Marine05's Avatar
I was a bit in a hurry this morning. I did try to see if the ignition key fit the door and it was not going in very easily and did not want to force it. When I get home from work I will try again.
Old Jan 25, 2011 | 12:16 PM
TomSRT's Avatar
that happened to me as well. it should open with the key. a little wd-40 works wonders.
Old Jan 25, 2011 | 03:59 PM
Goldwing's Avatar
Roadster, huh? First check to see if the top is down. If not, the key will open the doorlock. It is not dependent on the battery or the electronics -- I had to prove that to my son when he was "locked out" of his 2007. An occasional spray of WD40 or silicone in the doorlock is good preventive medicine. You should be able to do a search and find the 5 steps for re-synching your key to your ignition.
Old Jan 25, 2011 | 08:00 PM
Marine05's Avatar
Thanks everyone. When I got home from work I was able to get into the car and get it started. WD40 works wonders. Once I got into the car, I was able to pop the hood and saw that the negative terminal was not tight and could not be tightened any more due to corrosion. Next step... buy a new clamp/cable.
ingsoc39
Jul 7, 2022 04:25 PM
rayth
41
Jul 31, 2019 04:02 PM
mhajek18
Dec 30, 2015 03:40 PM
ultrajim49
17
Jun 27, 2015 12:20 AM
adamlevy
Jun 7, 2015 08:13 PM
