I thought this was pretty impressive!!!
Old Feb 4, 2011 | 07:58 PM
freakingfastsrt6's Avatar
Default I thought this was pretty impressive!!!
I do alot of business with braking and never really stopped to look at how big our srt6 brake set up really is....I took this picture today as im selling alot of my remaining stock!! and looked at my c5 CORVETTE front rotor and realized it just wasnt as heavy as the SRT6 front rotor...and realized what a difference it really was...for anybody upgrading to a bigger brake set up on this car is insane!!! Cause this would be one hell of an upgrade for a Corvette!!!!
Old Feb 4, 2011 | 08:18 PM
velociabstract's Avatar
Default Re: I thought this was pretty impressive!!!
I upgraded to a Stoptech 4 pot caliper and 355 mm 2 piece rotor. After spending the $$ I realized all I really needed were better brake pads or cooling ducts. The stock brakes are plenty with the right pads. What the hay, now I can abuse them all day and drink ice tea while all the rest are bleeding their brake fluid. Incidentally, our cars weigh more or less the same as a Z06.
Les
Old Feb 4, 2011 | 09:01 PM
32krazy!'s Avatar
srt has more cooling area and the vette disks have more reusable surface. im upgrading to 360mm rotors with 6 piston fronts and 330 rotors with 4 piston rears. that will get the job done!!
Old Feb 4, 2011 | 09:09 PM
I think you have that backwards...its the other way you mean right? The vette has much less reusable surface! but the vette does have more cooling!
Old Feb 4, 2011 | 09:35 PM
32krazy!'s Avatar
just went by the way your pics were posted. the first has the srt rotor on the right so i was guessing the other pics were set up the same way.
Old Feb 5, 2011 | 11:42 PM
ckovach's Avatar
There's no question the stock brakes are adequate, but they are absurdly heavy. The best reason to replace them is to lower unsprung weight. I dropped about 80 pounds by going to Brembo GTs all the way around.
Old Feb 6, 2011 | 03:16 PM
Montana Crossfire's Avatar
Sorry but you need a better scale...
NO WAY YOU COULD SAVE 80 LBS.
Actually ya couldn't save 20 lbs per wheel removing the brakes altogether
Old Feb 6, 2011 | 06:26 PM
WOW Im just gonna go ahead and call you a ROOKIE!!!!! 80 pounds??????????? What!!!!!! The whole rotor set weighs under that...the front rotors weigh about 23.5 pounds each in the front and about 15 in the rear.....!!
Oh typically when your upgrading your brake system your adding weight not dropping weight...unless your going with carbon ceramics!!!!!
Old Feb 8, 2011 | 03:56 PM
adriancin05's Avatar
actually im interested in buying the rotors both front and back... how much are you asking for them ?
blackpepper
Dec 18, 2021 06:17 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Sep 28, 2015 07:40 PM
rfourt
Sep 25, 2015 01:38 PM
lazorouss
Sep 11, 2015 09:16 AM
