new concern
Old Mar 17, 2011 | 10:30 PM
noles's Avatar
Default new concern
I have been going through halogen bulbs like crazy...In the last 8-9 months, I have had to replace my low beams...I've replaced the passenger side twice and the drivers side once...Now today the drivers side went out again...Has anyone else experienced this problem? By the way, changing the drivers side light really sucks ...I have to do that tomorrow.
Old Mar 17, 2011 | 10:35 PM
Montana Crossfire's Avatar
Default Re: new concern
I am unable to give you the reasoning but I do know foresure there is something WRONG...
Mike
Old Mar 17, 2011 | 10:51 PM
I would look at the contacts on the bulb holder and look for arcing. Poor contact and a fluctuating current does a lot of harm to bulbs.
In the old days a bad voltage regulator could send too much voltage to the battery, check that as well. If the voltage is too high the bulbs burn out prematurely.
I thought the passenger side was the worst to fix.
Old Mar 17, 2011 | 10:53 PM
It just dawned on me.
Are you using an after market Colored bulb?
Also some of those "Brightest" bulbs don't actually obtain there higher lumen output through science they mearly bump the Wattage.
Brighter yes but they burn out very quick.
If you answer yes to either of these qiestions you need to switch either to a quality HID or Sylvania Silverstar Halogins. I have 4 extra I could give to you at a good price.
Mike
Old Mar 17, 2011 | 11:02 PM
Mike
OEM bulbs are 55 watt and you cannot get any legal ones higher than that. You can buy Osram Rallye bulbs which are over the legal wattage (65) and they are supposed to last very well and are classed plus plus.
They are $20 or $25 each, do a Google search and you will find them. Silver Star's are the ones that burn out quickly according to previous replies on the forum.
I think that they are brighter because the filament is thinner and burns more intensely and that results in the short life.
Old Mar 17, 2011 | 11:21 PM
noles's Avatar
I only put the regular H7 bulbs in there...The last one I got from work...It's the same ones they use for BMW's...Some BMW's have that problem and they fix it with programming which sends less current to the bulbs
Old Mar 17, 2011 | 11:24 PM
180, I have to disagree with you there. I have run many Silverstars in different vehicles and have had NOTHING but good luck with them.
I have to say Sylvania seems to know what their doing in the bulb department. To each his own.
Mike
Old Mar 17, 2011 | 11:27 PM
Plus who said anything about legal???
Old Mar 18, 2011 | 12:47 AM
ammoman's Avatar
are you using gloves when replacing them? the oil on your hand will cause failure.
Old Mar 18, 2011 | 01:23 AM
RaulRocks2's Avatar
I agree with ammoman, if you touch the bulb by mistake when replacing it, it would shorten the life dramatically. Other than that I really don't know.
gp1200x
Dec 6, 2015 12:59 PM
debradegiovanni
Sep 27, 2015 09:39 AM
Big_Country
Sep 22, 2015 03:47 PM
MickeyNasty
Sep 6, 2015 08:29 PM
glover
U.K.
Aug 24, 2015 08:03 AM
