power seats
Old May 5, 2011 | 10:44 AM
nujersey's Avatar
Default power seats
just bought an 05 srt-6 was told by a chrysler tech the power seats only work if a door is open. it doesnt say so in the manual. ithought this a little strange, ive had 30+ cars and never ran across anything like this. is it true or is the tech just blowing smoke
Old May 5, 2011 | 11:07 AM
Default Re: power seats
The seat relay is half broken and yes, he is blowing smoke up your a s s.
Get the relay changed if you have a warranty of some form.
Old May 5, 2011 | 11:10 AM
tighed1's Avatar
Welcome to the forum nujersey!
More info for ya
Originally Posted by sonoronos
The power seats in this car have a special relay hooked up to the car's door open/closed sensor. It is called the seat relay.
The relay should only allow the seats to be adjusted when the door is open or the key is set to ON.
If the seats do not move when the key is set to ON, you may have to test and replace that relay.
Please check to see if the passenger side seat suffers the same problem.
Note: Edited to reflect that the car only has one seat relay that controls both passenger and driver's side seats.
Old May 5, 2011 | 11:19 AM
nujersey's Avatar
am i correct when i say you either have to have a door open or the key in the on position for the seats to move. how about if the car is movingg
Old May 5, 2011 | 11:31 AM
More info for ya
That post is wrong, the seats will move with the door open, closed and with the ignition on or off, as long as the relay is working properly. If one of the two diodes in the relay is broken it will only work with the door open or closed. The seat can be adjusted with the car in motion just as long as the relay is OK.
You should not adjust the seat while moving if the relay works only with the door open.
Old May 5, 2011 | 01:02 PM
tighed1's Avatar
Thanks for that.
I always thought that my seats adjusted at all times.
Thought everyone else had problems!
Old May 5, 2011 | 01:22 PM
Thanks for that.
Mine only worked with the door open last year and I swore it once worked all the time. So I yanked the relay, repaired it and all was right with the world again.
Old May 5, 2011 | 02:39 PM
arejohn's Avatar
Seats "only" work with the door open or closed. I;m gonna think about that on the way out to check it.
Old May 5, 2011 | 02:46 PM
Don't strain anything. "I;m" thinking you might.
Old May 5, 2011 | 06:45 PM
ws6vert's Avatar
Those tech's. Funny guys.
Old Jun 13, 2011 | 06:44 AM
cisa's Avatar
I am having an intermittent problem with my power seats working. Sometimes they both work and sometimes nothing. Sounds like I should first replace the "seat relay." Where is the seat relay located?
Old Jun 13, 2011 | 11:35 AM
Try here.
https://www.crossfireforum.org/forum...tml#post525788
Old Jun 13, 2011 | 11:54 AM
corfire's Avatar
Here’s an old post of mine about my seat operation, and a response from Hangman about his logic about the operation. The response is based on a roadster. However coupes originated from a SLK roadster?
My post on 5/24/08:
In my '04 coupe, my seat operates if the ignition is on and the doors are closed, but it does not work if the ignition is off and the doors are closed. But, it does work if the ignition is off and the driver’s door is open? I don't get the German logic on this one??
Response from member Hangman on 5/24/08:
It does make absolute sense. There are two pockets behind the seat that can be used to hold things (flat things). If you have the top open and the car locked, you don't want someone to be able to just reach in and move the seat forward and grab whats in those pockets. Thats why you can only move the seats with the door open (meaning you have the key to unlock the door) or with the ignition on and the doors closed. Similar to the reason why they made the central locking button deactivated once the engine is turned off, so that it prevents someone from reaching in and unlock the doors and alarm when you park with the top down.
Old Jun 13, 2011 | 11:57 AM
cisa's Avatar
Thumbs up Re: power seats
Thanks. A picture is worth a thousand words, but they didn't want to make it easy!! This may be an all day job.
Old Jun 13, 2011 | 03:43 PM
My post on 5/24/08:
The hangman is wrong, its bad when the hangman is wrong. The seats operate with ignition on or off, doors open or closed or any combination of those conditions. Unless the roadster is different of course.
I'd say the relay has a diode failure in the relay. My seats only operated with the doors open and the ignition on or off. I replaced one of the two diodes, 10 cents each, and they now work as stated above. I always wondered what the other diode affected and now I may know.
Old Jun 13, 2011 | 04:45 PM
corfire's Avatar
Here's info that you posted from the shop manual in a previous thread that desribes the way mine works, but is different from your current discription?
From the Shop Manual
OPERATION
The power seat lower switch adjusts the bottom portion of the seat forward and backward as well as tilting upward and downward both in the front and rear when the switch is pressed in that direction. The back portion of the seat reclines when the power seat rear switch is tilted forward or rearward. The driver side power seat switches areoperational with the driver door open, regardless of the ignition switch key position. If the driver door is closed, the ignition switch key must be turned to the ON/RUN position. See the owner’s manual in the glove box for more information.
Valk
Jul 12, 2021 09:49 PM
Apr 28, 2016 02:04 AM
steps
Apr 26, 2016 06:21 PM
atdavis2
Sep 21, 2015 01:25 PM
steps
Sep 19, 2015 10:43 PM
