Steve (32Crazy) should be proud of me!
Old Jul 23, 2011 | 05:35 PM
grip grip's Avatar
Default Steve (32Crazy) should be proud of me!
A while back I had a stainless manifold bolt seize in my supercharger. I tried to get crafty removing it and ended up breaking it off.
I drove over to Steve's and even he was unable to remove it without likely breaking an easy-out off into it and making things worse.
Well, today I finally got off my a$$ and decided to fix it.
I went out and bought a tap-and-die set but was unable to find a long enough drill bit to drill through the manifold into the supercharger. I did some head scratching and came up with an alternative.
I used the manifold gasket to transfer the bolt locations onto a metal template. After drilling the holes into the metal, I had to improvise a bit (stacks of washers) to secure the template in place on the supercharger. After securing the template I drilled out the hole with a 7/32" bit and taped it to a 1/4" FT. Hopefully I'll find a new bolt without too much aggrevation.
Old Jul 23, 2011 | 06:28 PM
32krazy!'s Avatar
Default Re: Steve (32Crazy) should be proud of me!
glad you were able to get the bolt out anthony. fastenal will have whatever size bolt you need in any size thread pitch. my gaskets will be here next week if you need a set
Old Jul 24, 2011 | 04:16 AM
kolevski's Avatar
This happend to me twice, I nearly put a hammer through my windshield I was so frustrated. I took it to my mechanic he fixed it, went home went to re-tighten it and BANG snapped another one again back to the mechanic.
What is it with these staniless bolts? I think the stock material does a better job.
John.
Old Jul 25, 2011 | 06:30 PM
goodgenes79's Avatar
I am dealing with this right now. I snapped one of the ss bolts off and have totally buggered the hole. I think I will have to have a local shop weld the hole and retap. What a frustration. Mine seized trying to loosen it back off. The manis weren't sitting properly due to y pipe turned a bit. Anyway, as I was trying to loosen everything completely and line everything back up, it snapped. I did a terrible job of trying to get it out and now the hole is too big and not centered where it was.
Old Jul 25, 2011 | 07:23 PM
grip grip's Avatar
John.
I'm really concerned now with removing the rest of the stainless bolts, but I'll be replacing the stainless bolts with the stock aluminum bolts as soon as I can find some at a decent price. Good luck.
Old Jul 25, 2011 | 07:27 PM
32krazy!'s Avatar
FASTENAL!!! quit making this so hard!
Old Jul 25, 2011 | 07:33 PM
grip grip's Avatar
I went to Fastenal and they couldn't help. They could if I wanted 5,000 1/2" x 4" hex bolts, but I wasn't in the market.
Old Jul 25, 2011 | 07:42 PM
32krazy!'s Avatar
your going to the wrong store. my guy just ordred me 4 12mm shank bolts necked down to 10 mm threads for 5$. when my manis show up ill order some
Old Jul 26, 2011 | 09:53 AM
grip grip's Avatar
Here's an article on using aluminum solder as a repair method. From what I just read, this seems like a pretty straight forward method of repairing a damaged boss.
http://gasengine.farmcollector.com/E...Does-Work.aspx
Old Jul 26, 2011 | 12:51 PM
heli arc, and the right rod would be better...
Old Jul 26, 2011 | 12:54 PM
grip grip's Avatar
Personally I'd be reluctant to arc weld with all the electronics on the car, unless of course the supercharger was removed from the engine.
Old Jul 26, 2011 | 12:55 PM
It won't hurt anything....is it stock intake bolts you need or something else...
Old Jul 26, 2011 | 12:56 PM
grip grip's Avatar
I need the stock intake bolts that secure the manifolds to the supercharger.
PimpDaddy
Mar 31, 2020 07:22 PM
wannaGOFAST
South Forum
Aug 14, 2015 01:20 AM
csteve0355
Aug 1, 2015 09:48 AM
skeet370
Jul 18, 2015 01:02 PM
mattnelson71
Jul 18, 2015 01:00 AM
