IAT Sensor placement
Old Nov 2, 2011 | 06:17 AM
blackpepper's Avatar
Default IAT Sensor placement
I have did a search but didn't find my answer. Will IAT sensor placement affect performance? I have a custom dual intake an I placed my sensor upstream midway of my driverside intake tube and wrapped the wiring with heat wrap.The car
r is more responsive with better midrange any downside to moving the sensor from the stock location since it see a lot of heat there.
Old Nov 2, 2011 | 06:24 AM
Default Re: IAT Sensor placement
if it is where it will read cooler temps, I think you did fine...sounds like you did just that...
Old Nov 2, 2011 | 06:46 AM
Thanks that's what I did
Old Jun 25, 2012 | 08:55 PM
Mrmiata's Avatar
I'd wager you'll be cleaning the exhaust tips a little more.. since it's not the "true temp" of the air the maps are set up for. But what do I know.. put it inside with the ac .. Those "POS Performance chips" basically do the same thing..
Edit.. Hey Jen.. good to see you again.. How'd that compression test turn out?
Old Jun 25, 2012 | 10:33 PM
'She' is a troll, read the posts with her name on. Most of them lead you to another site.
Old Jun 25, 2012 | 10:36 PM
Mrmiata's Avatar
Canadians... hmm... TROLLS NEED LOVE TOO!
Maybe she just needs someone to talk to.. and listen.. and care just a little..
Old Jun 29, 2012 | 10:18 PM
BrianBrave's Avatar
<--- Huge Horsepower
Boost tap on one side - IAT tap on the other
That is if you want to know what the ECU is seeing.....
rampntlion
21
Feb 11, 2019 08:18 AM
ritous1
Sep 26, 2015 01:27 PM
caseydeankopp
Sep 13, 2015 07:25 PM
bobbie
Sep 12, 2015 12:49 PM
2004_
Sep 4, 2015 01:39 PM
