Looking at one tomorrow
Old Dec 18, 2011 | 11:20 AM
BLACKSRT-6's Avatar
Default Re: Looking at one tomorrow
I have to agree with you. Even Rudy has told me they are not VIN specific. Model specific may not be the most accurate way to describe it. the reason the SRT TCU won't work in a n/a has to do with the difference in gearing in the trans and the different rear end ratio. I was in pretty constant contact with Rudy during his forst V8 conversion. Since he used the trans from a 55K car he had to use the TCU form the car as well as change the rear end to 3.07 There is a speed sensor in the trans. If the TCU thinks this speed is out of wack to the speed of the car you won't go very far.
BTW, Mopar has an upgraded Siemans TCU for the Hemi cars that use our trans. If the Hemi/SRT8 trans has the same gear ratios as the SRT and also uses a 3.07 rear gear, the mopar TCU just may work and is very reasonably priced. Other wirring would need to be verified but very worth looking into.
I spoke with Rudy on this issue after having problems with my TCU. The TCU from another SRT-6 will work in your SRT-6 "After" it has recieved a physical chip reset. This was only after trying 4 different SRT-6 TCU's in all three of my SRT-6 cars. All went limp without their own TCU installed.
32 Crazy - Your SLK appears to be somewhat different than the SRT's in my garage. I have also been working with Jerry resolving TCU issue over the past three months. He initially swapped my son and my TCU's while they were out of thier cases. When the incorrect TCU's were installed after the TCU mod, both cars went into limp mode. I am still working with Jerry to correct the TCU not holding gear and bouncing off the rev limiter issues. Jerry has explained that several TCU variations were available over the years causing inconsistancy in TCUs and TCU mod results.
Also, my cars will not upshift until they reach the correct RPM for the gear. If I am at 10MPH and select 5th the car will not upshift to 5th until the ECU/TCU agree that the car is at a safe speed. It will upshift through the gears as I achieve the next safe speed point.
Old Dec 18, 2011 | 12:43 PM
32krazy!'s Avatar
not sure why there would be any differences. the entire driveline computers and suspension come right out of the discontinued slk32 amg's. i can swap parts with the srt and the part # are identical. the issue with yours could be the modded tcu's. perhaps theres a file that was messed with that caused the limp mode. i had latemodel21 (chris) ship me his oem tcu from his spare slk32 and it worked without any issues at all. reinstall my modded tcu and all my datalogg issues returned. i can easily swap the tcu with jhm2k new srt-6 and confirm the swapability or not when rob sends my thermalcoated intake parts back.
Old Dec 18, 2011 | 06:31 PM
BLACKSRT-6's Avatar
All that I can tell you is that I have tried 4 TCU's. 2 Modded and 2 stock in 3 different SRT-6's. The only configurations that worked were the original TCU from that car, and that the information that I recieved from Rudy and Jerry indicate that the Crossfire TCU is car/vin specific until physically chipped. Also, there is a difference between the original coding version of the EGS controller, one car is 2 versions changed from the other. This is appearently part of the problem with one of the SRT-6's not accepting the full TCU mod.
Old Dec 18, 2011 | 06:42 PM
32krazy!'s Avatar
rob texted me today that my parts should be done monday. hopefully i will get them before the holiday weekend and have my v2 tcu back in for datalogg. over the weekend ill swap jhm2k's tcu into my car and see what happens. ill let you know
Old Dec 19, 2011 | 08:10 AM
TomStratRT's Avatar
Originally Posted by Muskaroxs
VIN 1C3AN79N85X057255
Black
65,000 miles asking $15,900
Is that a fair going rate if the car looks and drives well?
I'm thinking around $14,000 based on what Ive been reading here.
Thanks
I bought mine a little over a year ago for about $18,000 with 16k miles. I think you could do better. Although the trend these days with Crossfire sellers is to jack up the price due to the rising rarity of the car.
amx1397
Apr 24, 2025 07:31 PM
blackpepper
Oct 4, 2017 06:09 AM
user 8202
Canada
29
Nov 11, 2015 05:27 PM
Abaton6
Sep 24, 2015 10:14 PM
Diabla
Aug 20, 2015 10:50 AM
