Need Dashdaq setup help for boost from the MAP.
Old Feb 7, 2012 | 10:57 PM
grip grip's Avatar
Default Need Dashdaq setup help for boost from the MAP.
I'm trying to configure the Dashdaq to read boost from the MAP from the OBD2. I've tried following Rob's instructions from a while back, but they aren't working for me. I would get the info from the Dashdaq forum, but the servers have been down since last week.
Thanks in advance for the help.
Old Feb 8, 2012 | 08:46 PM
grip grip's Avatar
Default Re: Need Dashdaq setup help for boost from the MAP.
Here's the settings from the manufacturer that worked like a charm:
Try these settings in your calculator:
Input Signal: MAP
Multiplier Signal: Constant Multiplier from Rescale Calculator
Multiplier Sign: 1
Constant Multiplier: 1
Offset Signal: Constant Offset from Rescale calculator
Offset Sign: -1
Constant Offset: 14.7
Old Feb 8, 2012 | 10:11 PM
grip grip's Avatar
For those wanting to connect their widebands to the Dashdaq without spending $50 on the wideband add-ons, you can connect the analog wire from your wideband to the Dashdaq cable and adjust your settings this way:
Offset: 7.35
Factor: 3.008
Old Feb 13, 2012 | 05:45 AM
Russcross's Avatar
Offset: 7.35
Factor: 3.008
Thanks for the info! One question - where did you place dashdaq in your interior, it’s quite big and doesn’t look nice but still very needful thing to have!
Old Feb 13, 2012 | 06:27 AM
grip grip's Avatar
I mounted it on the windshield with the supplied suction cup mount.
Old Feb 13, 2012 | 08:01 AM
Russcross's Avatar
Have you got any photo of that?
Old Feb 13, 2012 | 05:03 PM
32krazy!'s Avatar
its smaller than my garmin gps. i had a friend make me a custom bracket and mounted mine just to the laft of the mirror using the oem visor screw. ran all the wiring up the a pillar and across out of sight.
Old Feb 13, 2012 | 07:03 PM
grip grip's Avatar
+1 on what Steve said. Here's a photo of my Dashdaq beside my Nav unit.
Old Feb 13, 2012 | 07:19 PM
32krazy!'s Avatar
heres my setup
Old Feb 13, 2012 | 07:24 PM
grip grip's Avatar
Originally Posted by 32krazy!
heres my setup
Your Dashdaq is at least 10 times smaller than mine.
Old Feb 13, 2012 | 07:27 PM
32krazy!'s Avatar
dont know how to make as big or as fast as yours!!
Old Feb 13, 2012 | 07:29 PM
grip grip's Avatar
You've got the "fast" part covered, but mine will always be bigger.
Old Feb 13, 2012 | 07:33 PM
32krazy!'s Avatar
OUCH!! i walked right into that one!
HOT FIYA
May 31, 2019 08:01 PM
kaz1961
Mar 8, 2016 04:07 PM
Sep 28, 2015 07:40 PM
velociabstract
15
Sep 7, 2015 03:43 PM
waldig
Jul 30, 2015 07:39 PM
