Points for Pre-Purchase Inspection?
Old Apr 21, 2012 | 07:53 AM
Cribbj's Avatar
Default Points for Pre-Purchase Inspection?
Hello everyone, new member here. I joined the forum because I'm considering purchasing an SRT-6 roadster.
Would anyone have a list of known trouble points for this model that should be inspected/verified prior to purchase?
I've searched and found the excellent thread of fixes to known problems, but am curious to know if there's a compiled list of what to look for before buying.
Many thanks in advance,
John
Old Apr 21, 2012 | 09:42 AM
MikeBrink28's Avatar
Default Re: Points for Pre-Purchase Inspection?
Check for oil leaking from the mani gaskets
Old Apr 21, 2012 | 09:48 AM
TomSRT's Avatar
John
see
https://www.crossfireforum.org/forum...crossfire.html
good luck
Old Apr 21, 2012 | 12:46 PM
Cribbj's Avatar
Thanks everyone. So besides the usual mechanical checks and inspections, it looks like the following items are to be expected with the SRT?:
Door pulls with sharp edges
Oil leaking from intake manifolds
Valve cover oil leaks
Seat warmers don’t work
Rust/Corrosion underside of doors behind gaskets
Radiator TSB?
Sticking ignition
IC pump not working
It really seems to be a fairly trouble free car.
My preference would be for an SRT roadster in lieu of the coupe - anything special to look out for on these models?
Old Apr 21, 2012 | 12:53 PM
magredvet's Avatar
Want a low mileage (7800) SSB roadster, check out the cars for sale section......... :O)
Old Apr 21, 2012 | 02:21 PM
ModlessG's Avatar
Transmission leak at the fill tube gasket seems pretty common as well.
Old Jul 17, 2013 | 10:47 AM
fyrepower's Avatar
where is the fill tube located? need to add fluid
TerryR
Dec 13, 2019 03:27 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
jimf
Oct 10, 2015 10:22 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
