DIY Dual CAI Tee Splitter FOUND
Old Jul 23, 2012 | 11:13 AM
jiggityjosh's Avatar
Banned
Default DIY Dual CAI Tee Splitter FOUND
I don't know if anyone has found this. I SWEAR on ALL THAT IS HOLY, that I found a WYE splitter earlier, but now I can't find it... but here is a 3" Tee splitter... for 30$
http://intakehoses.com/Merchant2/mer...egory_Code=RT4
Would it work?
Old Jul 23, 2012 | 11:19 AM
maxcichon's Avatar
Default Re: DIY Dual CAI Tee Splitter FOUND
Yep. But you'll need this, too:
Silicone 90 Degree Reducing Elbow 3.5" to 3" ID: Intake Hoses, IntakeTubing, and Intake Clamps
And a short bit of 3" aluminum tubing, and a couple of clamps...
Old Jul 23, 2012 | 11:22 AM
Banned
The splitter is already 3" in all three ports!
Old Jul 23, 2012 | 02:37 PM
Max, I went to that site you posted. I could have had a 3" to 5" CAI....can you image the look from my front grille with 2 5" tubes hangin' out there....d@mn. Guess I will just keep my little Needswings...lol
Old Jul 23, 2012 | 02:46 PM
maxcichon's Avatar
But, the throttle body is > 3 3/8".
Old Jul 23, 2012 | 03:28 PM
Black Rubber Intake Tee 3" ID: Intake Hoses, IntakeTubing, and Intake Clamps
Would it work?
Yea, BUT : "90 degree bends ain't a CAI's friends "
Old Jul 24, 2012 | 08:23 PM
Banned
@Maxcicon - I ordered this... Aluminum Intake Reducer 3.5" OD to 3" OD: Intake Hoses, IntakeTubing, and Intake Clamps
@alaxfire - I also ordered these...
1' 45 Mandrel Bent Aluminum Pipe (Four of them)
1' Straight Aluminum Pipe (One of these)
2' Straight Aluminum Pipe (Two of these)
Silicone Coupler Hoses (Six of these)
Washable air filter media. (Two of these)
3.5" Exhaust Clamp (One of these)
3" T Band Clamp (Thirteen of these)
I will be using the 1 foot pipe to go THROUGH the T Splitter, cutting a 2" diameter hole above the 3" opening, then cutting 1 inch spaced "notches" around the inside to the full 3" diameter. Push the 1 foot tube THROUGH the splitter, then reach in the Throttle body hole and bend those DOWNWARD to create a sturdy, 3" diameter hole. Then I will take a hatchet and bend a notch ABOVE that whole, to create an inward bend, directing the air towards the throttle body. It's SUPER custom, but I think it will all work out. I'll let you guys know how it works and post pics if it does!!!!!!
Old Jul 24, 2012 | 08:35 PM
Banned
That Aluminum intake reducer is 3 3/8 inside diameter because it is 1/16th thick and the outside diameter is 3.5 so that makes the inside diameter 1/8th smaller than 3 4/8 = 3 3/8 IT'S PERFECT!
Old Jul 24, 2012 | 08:56 PM
maxcichon's Avatar
One way or the other, I'd like to see this. You can see mine in my sig. If you come up with a better way-Cool!
Where are the filters going?
Old Jul 24, 2012 | 09:08 PM
Banned
I live in Utah so I have already installed custom "Devil Horns" and cut out the top right and left "flaps" in the grill to provide more aerodynamic suction and flow into the horns. You can literally feel the suction even when in PARK... But that's connected to the stock airbox and tubing. The filters will be going INSIDE the engine compartment but I will be installing heat shields and routing the devil horns directly inside of them.
Banned
Oh and it snows/rains ALOT in Utah so the front mount filters was NOT an option for me.
Old Jul 24, 2012 | 09:59 PM
Mrmiata's Avatar
Too funny... While patiently waiting for a turbo kit...
Rubber Tees: Intake Hoses, IntakeTubing, and Intake Clamps
Type of file: Internet Shortcut (.url)
Description: Rubber Tees Intake Hoses, IntakeTubing, and Intake Clamps
‎Created: Sunday, ‎June ‎24, ‎2012, ‏‎1:55:07 PM
Old Jul 25, 2012 | 08:07 AM
Banned
Old Jul 25, 2012 | 09:22 AM
Mrmiata's Avatar
Note the date of my desktop shortcut?
Old Jul 25, 2012 | 08:04 PM
Southernscrew's Avatar
Try here under 4in components. they are listed in all shapes but don't know if you can use 4in.
Spectre Performance - Official Site -- --
Old Jul 25, 2012 | 08:10 PM
waldig's Avatar
Talking Re: DIY Dual CAI Tee Splitter FOUND
The 90 bends will have you working to get the pipes to line up, there is an offset in the NW Tee that I worked on. YOu could get it to work, just lots of tweeking to get it to go. ENJOY Woody
Old Jul 25, 2012 | 10:28 PM
Banned
I changed everything. I will be using two 45 bends, very similar to the setup the twincharged SRT-6 uses on the driver side. Should merely be a matter of cutting a couple pipes to fit and g2g!!
I listed ALL of the parts that I ordered already a couple posts ago also.
Old Jul 25, 2012 | 10:56 PM
Mrmiata's Avatar
I'm banking on the Turbo .. but just as an FYI - could you post your total or do I need to run them down? Getting late.. lol.
Old Jul 25, 2012 | 11:01 PM
Banned
With the T Coupler, the Aluminum reducer, the couplers, clamps, piping and filters... My total is about 260$ including shipping.
Old Jul 25, 2012 | 11:20 PM
Mrmiata's Avatar
That's not bad at all.. Considering the Needswings single is a 450 date, and the dual looks much better, but is noted as "overkill" for the NA and an 800 dollar date, I'd have to say a nice savings and probably all the air flow she can deal with. Just looking for an alternate should things go wayward with the Turbo build. Seems a few are ready to break out pitch forks and see it killed off than sit quietly and wait.
Keep us posted of developments.
