Dyno Number thread (graphs+mods info+and more)
Old Oct 30, 2012 | 08:59 AM
JesseJamessrt6's Avatar
Default Re: Dyno Number thread (graphs+mods info+and more)
Originally Posted by trevorradman
Eurocharged SC pulley
Eurocharged tune
Nw dual cai, psk
Intercoolers
Cm30 pump
He isolation
Resonator delete, dashdaq, zt2, catch can
Driver mod
Stock wheels/tires
16 lbs Boost at 6000'+
368/361 corrected
302/296 uncorrected
Thank you for the info on dynoing and thanks for posting your numbers.
Old Oct 30, 2012 | 11:39 AM
FUBU's Avatar
Eurocharged tune
Nw dual cai, psk
Intercoolers
Cm30 pump
He isolation
Driver mod
Stock wheels/tires
368/361 corrected
302/296 uncorrected
Which EC SC pulley? 61 or 64.7 ?
Old Oct 30, 2012 | 11:59 AM
velociabstract's Avatar
From the boost number it's a 65 mm pulley.
Les
Old Oct 30, 2012 | 12:05 PM
FUBU's Avatar
Les
Cool! Thanks for posting.
Old Oct 30, 2012 | 08:09 PM
trevorradman's Avatar
It only gave me 3 PSI if that tells you, although I'm betting the gains are less at altitude. I asked them for the smaller pulley and was told they only had one pulley. I gained just as much with the Needswings DCAI.
Old Oct 30, 2012 | 08:13 PM
With my Code 3 at sea level I saw a maximum of 17.9 PSI. With a 178 ASP crank pulley I see a maximum of 19 PSI at sea level. Just so people know, more or less what to expect.
Les
Old Oct 31, 2012 | 02:42 AM
FUBU's Avatar
Always different on different cars, location, measuring. But I guess a 61mm could give 20 psi boost. Maybe somewhat less than a 185 crank pulley.
Old Oct 31, 2012 | 10:27 AM
boostmonkey's Avatar
Actually it should be slightly more than the 185 pulley. The pulley ratio is slightly higher.
These new 62/61 mm pulleys should make some GREAT HP. Exciting times!!
Old Oct 31, 2012 | 10:34 AM
FUBU's Avatar
Awesome numbers! Great news! Just got myself the 61mm. The 64.7 I have today will be put on the shelf together with stock. Unless someone will buy it
Old Oct 31, 2012 | 05:58 PM
xman03's Avatar
Banned
It sucks that the guys at higher altitudes are getting such low uncorrected numbers. I'm very glad to be at sea level.
Apr 28, 2016 02:04 AM
johnnycross413
Mar 4, 2016 04:49 AM
4drturbo
Oct 2, 2015 12:58 PM
Sep 28, 2015 07:40 PM
Sep 25, 2015 07:46 AM
