Dyno Number thread (graphs+mods info+and more)
Old Aug 3, 2012 | 04:53 AM
FUBU's Avatar
Default Dyno Number thread (graphs+mods info+and more)
Hi,
I thought it could be cool to gather all dyno numbers in one place.
So feel free to add dynographs including what mods,tunes etc have been used.
I would like to see what numbers i.e. mods like EC SC pulley (#2) + DCAI (x3m) + EC tune + PSK, will come up to and I guess many have this setup and have made dynos. Of course all cars behave differently, but I guess it is better than guessing.
So who will be the first one to add?
Old Aug 3, 2012 | 05:47 AM
FUBU's Avatar
Default Re: Dyno Number thread (graphs+mods info+and more)
EC TUNE
EC SC 64.7mm PULLEY
Old Aug 3, 2012 | 11:15 AM
ZAHANMA's Avatar
Don't have my dyno sheet in digital form, but last dyno was just a couple weeks ago.
Dyno Dynamics: 367rwhp @ EC (95* outside temperature)
Modifications:
- NW DCAI
- Modified Stock Manifolds (Ported/Polished/Coated)
- EC 185mm Crank Pulley
- Supercooler
- NW Split Cooling
- Ported/Polished/Coated Y-Pipe
- NGK 1-step colder plugs
- Magnacor 8.5mm Plug Wires
- Bigger Injectors (25% over stock)
- Looped Fuel Rail
- Walbro Fuel Pump
- EC Stage III Custom Dyno Tune
Dyno's are just a tool for proper tuning, so everything should be taken with a grain of salt. However, in cooler weather there is probably another 20rwhp that would "show up" on a dyno.
Old Aug 3, 2012 | 02:32 PM
32krazy!'s Avatar
who cares what the dyno says? 11.9@ 115mph!!! thats the real test
Old Aug 3, 2012 | 04:47 PM
ZAHANMA's Avatar
I bet I can pee farther...
Old Aug 3, 2012 | 05:40 PM
velociabstract's Avatar
Without a graph I don't believe you!
Les
Old Aug 6, 2012 | 09:01 AM
ZAHANMA's Avatar
Les
It's ok, I have one of those...here, let me show you.
Old Aug 6, 2012 | 09:05 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
lol.
Judging by the graph, Steve may want to get the old prostate checked.
Old Aug 6, 2012 | 09:11 AM
Beaner's Avatar
There was some issues getting a good reading. Since then we think we got it sorted out so it will need to be updated. Here is what I had from a year and a half ago
Old Aug 6, 2012 | 10:48 AM
trevorradman's Avatar
309 HP
307 Torque
100% Stock from filter to exhaust.
Uncorrected 247 HP 245 tq at 5700', 93 degrees.
Old Aug 6, 2012 | 11:52 AM
FUBU's Avatar
Worth making a sticky?
Old Aug 7, 2012 | 10:42 PM
Modifications:
- NW DCAI
- Supercooler
- NW Split Cooling
- Looped Fuel Rail
- Walbro Fuel Pump
Do you and Eurocharged post up the corrected or unorrected numbers?
Old Aug 8, 2012 | 05:25 AM
32krazy!'s Avatar
lol.
mine is uncorrected , matt had to have his graph corrected!
Old Aug 8, 2012 | 08:52 AM
ZAHANMA's Avatar
Uncorrected.
Old Aug 8, 2012 | 08:55 PM
JesseJamessrt6's Avatar
I had no idea what corrected vs uncorrected meant so I read up here Equations: Dyno Correction Factor and Relative Horsepower south texas is far from Detroit...
Newbie questions here- How do I plan ahead with a dyno to get a digital dynograph? Does it just matter on the setup of the dyno and weather they offer a digital file? Do you bring a thumb drive or do they e-mail it to you? I have the same question for the digital time slips from a drag strip too. Also, can anyone explain what gears the most accurate dyno run's are and what is typical?
Old Aug 12, 2012 | 06:25 AM
daithi2's Avatar
458hp 489tq cutouts open
451hp 497tq cutouts closed
dyno video
SRT-6 Dyno 458hp - YouTube
mods: alot+squeeze
Old Aug 12, 2012 | 08:49 AM
Those are awesome numbers!!!!!!!!!!!!!
Old Aug 13, 2012 | 04:36 PM
Find a comany that does 3 Dyno pulls with Air/Fuel for ~$100. Setup an appointment. They will do a printout and or email you the graphs. You want them to pull in 4th gear, closest to 1:1 ratio, should be over 130 MPH on the graph, else they got wrong gear(happens on automatics that shift when they want). They will ask how high they can rev, I let them bounce it off the limiter.
Old Oct 30, 2012 | 12:40 AM
Eurocharged SC pulley
Eurocharged tune
Nw dual cai, psk
Intercoolers
Cm30 pump
He isolation
Resonator delete, dashdaq, zt2, catch can
Driver mod
Stock wheels/tires
16 lbs Boost at 5700'+
368/361 corrected
302/296 uncorrected
Old Oct 30, 2012 | 03:53 AM
FUBU's Avatar
Can someone make this a sticky?
