Noise from rear of car
Helping a freind trouble shoot a niose from the back of his car. Car is a limited, but can't see how that makes a difference. The clunk occurs from the back of the car when you let off the breaks after a hard breaking event. No other time, only when the breaks are released after hard breaking.
Any Ideas?
Any Ideas?
Re: Noise from rear of car
Turns out that it was a binding upper sway bar bushing. Made a heck of a racket, lubricated both sides and the noise was totally gone. I've never heard a bushing make that much of a clunk noise before.
Alaxfire, just some one I met at a local gas station. Has a limited and needed some help with this issue. I recommended the forum, he may be on soon.
I have been having a heck of a noise as well and can't figure it out. When the sway bar ranges up and down there is a "creaking" noise. Is creaking the same or similar to "clunk" noise? I can hear it while driving from inside and out side when jacking the suspension up and down. It started after the sway bar was contactin ghte upper control arm and pinching it up against the body seam after I lowered it. Since then I have adjusted the sway bar links out so the sway bar doesn't contact the upper control arm and took a grinder to the body seam to create a channel for the sway bar to ride in without contact. This is when the noise started. Hard to believe it would be a bushing making this noise as you guys pointed out.
Now to find where to buy a set of these? Any better links to ensure we get the part we are expecting than the following;
05099082aa
BUSHING. Stabilizer Bar, Sway Bar. for 2006 CHRYSLER CROSSFIRE SRT6, 3.2L V6 Supercharged, 5-Speed Automatic MB Roadster (05099082AA)
Dealer? Mercedes or chrysler?
05099082aa
Creaking is coming back,
I found these in Waldigs gallery! (shoudl have asked him first)
Newegg has them
Newegg.com - Energy Suspension 5.5115G Sway Bar Bushing Set
Newegg has them
rayth
41
07-31-2019 04:02 PM
frankthetank81
12-06-2015 06:25 PM
jimbo257
18
09-24-2005 09:03 PM
Mopar Doctor
09-15-2003 11:25 PM
