62mm pulley: fuel system OK?
Old Oct 23, 2012 | 02:21 PM
boostmonkey's Avatar
Default 62mm pulley: fuel system OK?
For you guys already running the 62mm supercharger pullley: Was the OEM fuel system sufficient, or were upgrades required?
Do you have logs of a wideband O2, fuel pressure, injector duty cycle, or other data showing that the fuel system was OK or not OK?
Old Oct 23, 2012 | 05:04 PM
Default Re: 62mm pulley: fuel system OK?
Don't have mine yet but I won't be monitoring all that. I will monitor fuel pressure, 02, but nothing else... I know there are some modified ones out there, but Rudy hasn't shipped them yet...hopefully this week they will ship...
Old Oct 24, 2012 | 12:58 PM
Billy22Bob's Avatar
All I can add are - Steve's thoughts....
https://www.crossfireforum.org/forum...tml#post645557
oh and of course.....take it or leave it.....my calcs suggest you need 580cc to maintain at least 12AFR at 6200rpm and 800cfm (62mm pulley+ supercooler)....550cc without a cooler...(ie: 36F hotter= 6% less density/power)
But as you quite rightly pointed out and in line with Steve's logs....my cfm and cc's may be 5-10% high...but that's not such a bad thing though when designing.
Old Oct 24, 2012 | 03:50 PM
cudaman's Avatar
Isn't 12+ AFR sort of "risky"?.... Staying in 11's I would think would be much prefereble, especially at WOT. If going 12, should measure knock retard too. Aeroforce Scangauge can monitor two parameters at once on a single gauge if you are going to push it. Better safe than sorry. XFire engines I am sure are not cheap to rebuild.
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
RacerXofFL
Sep 15, 2015 05:00 PM
81's
Sep 13, 2015 04:34 PM
