Spark Plugs...
Old Nov 19, 2012 | 06:43 PM
rfourt's Avatar
Default Re: Spark Plugs.....
Originally Posted by oledoc2u
this 60 year old man wouldn't have a bit of problem kicking your little smart ***
Love it! You are da' man! You can ride shotgun with me any day! The big question is do we use OC, Taser, baton or aluminum shampoo?
Old Nov 19, 2012 | 07:12 PM
caseycowan5's Avatar
this 60 year old man wouldn't have a bit of problem kicking your little smart ***...take a hike.....you haven't done **** except try to sell brakes you more than likely can't install. No one cares what you think.....and people are tired of reading about your 2300 dollar brakes...Hell, you need to go fast first.....
Yet again, so mature. Is the only thing you have on me is that i have brakes that you drool over and cant have. But, anyways i'm not here to make enemies so ill walk away and ill pm you some pics after I install them myself in my garage on my own lift. And i'm sorry i'm man enough to drive a stick, and you let me know when theres a working turbo system an ill buy it and put it on the same day. Thanks
Old Nov 19, 2012 | 07:13 PM
Threats now in my books that crosses the line and enjoy your ban. but if you want to go that far Ill bring my .45.
Old Nov 19, 2012 | 07:30 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Lets settle down gentleman... And stick to topic. Anymore ot and I will be forced to clean the post up and get back to the subject. To all... Thanks for your understanding.
Old Nov 19, 2012 | 10:40 PM
srtmodder's Avatar
Just asked about spark plugs but thank you for all the info!
And...
Old Nov 20, 2012 | 08:31 AM
Guran's Avatar
Ngk r5671a-7
Old Nov 20, 2012 | 10:58 AM
And...
Thats funny.
Old Nov 20, 2012 | 01:13 PM
And...
This did go to hell in a hand basket quickly. Someone saying they will bring a .45 is a bit over the top, especially as he had mentioned another person getting banned for threats.
I took the trouble to find what you had posted about your car and found you had previously stated it was a low mileage roadster. As the plugs last a long time normally and you did not mention problems, I stated that plugs were not required and this was backed up by Rob at Needswings saying the same thing. As he would gladly sell you plugs if you insisted, I took that as proving my point.
It appears that some people would save you the cost of twelve plugs and others would have you spend $120+ for no good reason.
Old Nov 20, 2012 | 09:42 PM
srtmodder's Avatar
Thank you.
Old Nov 21, 2012 | 02:56 PM
goodgenes79's Avatar
I have a question....
Rob has the nice laser iridium at stock temp and the regular iridium in a colder temp. I have had the colder plugs for about 40,000. was looking to get some new ones while the sale is on. Are the laser better for modded or should I stick with the colder temps?
Old Dec 5, 2012 | 11:00 AM
anyone have an opinion or knowledge for my above post?
Old Dec 5, 2012 | 02:06 PM
rfourt's Avatar
Here's some info from NGK http://www.ngksparkplugs.com/pdf/DYK...idium%20IX.pdf
Doesn't really address colder vs. stock, but does highlight the differences between iridium and laser iridium
Old Dec 6, 2012 | 01:10 PM
My guess is to stick with the colder plugs as I wouldn't use the benefit of 80,000 miles before a replacement on a modified drivetrain.
Old Dec 6, 2012 | 06:24 PM
Guran's Avatar
NGK R5671A-7, modified cars.
Old Dec 10, 2012 | 08:33 PM
Chris L.'s Avatar
Read this in an article about the c320.....same engine....
"These all-aluminum 90 degree V6 engines have an unusual valve arrangement, 2 intake and 1 exhaust, with 2 sparkplugs per cylinder, each with their own coil. The idea of the single exhaust valve is that the exhaust gas remains hotter, thereby improving emissions especially when the engine is still cold. A single exhaust valve also allows room for the 2 plugs which fire in sequence, first one then the other. This allows for,among other things, a much leaner mixture to be used for improved gasmileage and reduced emissions. After each firing cycle, the order in which the two plugs fire is reversed, allowing for a smoother engine with better control over engine noise."
Old Dec 27, 2012 | 01:12 PM
mrvideosawyer's Avatar
Man ;
It has been some time since I have been here - it seems like the whole group has a case of the Mondays. My question was HOW to change plugs (okay I know all of you are saying what a new be) BUT there are always tips and trick to be gleaned from a crowd. If you think changein plugs on crosfire is tough try it on a 1995 supercharged Corvette - now tha is a challenge.
Any tips on changing plugs on 2005 Crossfire
Thanks in advance Jim
Valk
Jun 22, 2025 09:15 PM
Goldwing
21
Apr 2, 2025 11:32 PM
cdcrone123
15
Nov 10, 2022 10:47 AM
Sep 28, 2015 07:40 PM
atdavis2
Sep 21, 2015 01:25 PM
