SRT6 Front Bumper Question
Old Jan 17, 2013 | 10:15 PM
OC Xfire's Avatar
Default SRT6 Front Bumper Question
Hi All,
I just received my much awaited SRT6 front bumper from the dealership, freshly painted and awaiting installation on my 2005 N/A Crossfire Roadster.
Can anyone tell me the difficulty level of putting the new bumper on my XF? I did a search on here to see if there was some sort of 'how to' or quick explanation, but I didn't see one.
Any input would be appreciated! LOVE the look of that lip on the SRT bumper and can't wait to get it on my car!
(And to be clear, I don't want the dealership installing it. My fiance works on cars all the time, but he wasn't sure if there are any tricks to installing it, or if it is pretty simple).
Thank you!
Old Jan 18, 2013 | 10:06 AM
rmaier's Avatar
Default Re: SRT6 Front Bumper Question
No too difficult if you are handy with tools.......headlights need to come out and the bottom splash pan needs to come out first then there are several bolts behind where the headlight was and 2 on the front behind the grill inserts also the 1's for the inner fender liners. About 2 1/2 hrs if you have never done this before. jusy be careful not to scratch the newly painted bumper. Alignit up correctly and you'd never know it didn't come from the factory with it.
Old Jan 18, 2013 | 10:14 AM
You do not have to remove the headlights, some people take off the bumper to get the headlights off.
From the manual.
FRONT FASCIA
REMOVAL
1. Raise and support the vehicle.
2. Remove the lower splash shield retaining screws
(1) and the lower splash shield (2).
Note: Left side shown, right side similar.
3. Remove the left and right front fascia access panel
retaining nuts and screws (1).
4. Remove access panels from the vehicle.
ZH FRAME & BUMPERS 13 - 1
5. Disconnect the fog lamp wire harness connectors
(1).
6. Disconnect the ambient air temperature sensor
wire harness connector (2).
Note: The front marker lamp harness connector
can be reached through the access hole in the
inner fender well.
7. Disconnect the front marker lamp wire harness
connectors (1).
13 - 2 FRAME & BUMPERS ZH
8. Remove the lower fascia retaining nuts (1).
9. Remove the left and right front fender to fascia
retaining nuts and bolts. (Refer to 23 - BODY/EXTERIOR/
LEFT FRONT FENDER - REMOVAL).
10. Lower the vehicle.
11. Remove the front grille assembly retaining bolts
(1).
12. Remove the upper fascia retaining bolts (1).
13. Remove the fascia from the vehicle.
Old Jan 18, 2013 | 11:51 AM
OC Xfire's Avatar
Thank you so much for the info, I really appreciate it!
Old Jan 18, 2013 | 12:26 PM
Down load the Service Manual from here. (Click)
You then get the pictures.
Old Jan 18, 2013 | 02:54 PM
bluecoupe's Avatar
Agreed, I managed to do it quite easily without removing the headlights and I'm all thumbs!
Old Jan 18, 2013 | 03:38 PM
Me too on both.
I have actually seen advice in other threads related to headlights to remove the bumper cover for easy access to the headlights.
Shucks, coulda even been me that advised that .......
Old Jan 21, 2013 | 12:32 PM
JEFASOLD's Avatar
Hi All,
Thank you!
They are all right, it isn't difficult, I just took mine off, took about 45 min.. But it is much easier if you have the right tools, you need the star bits(torx) , a 9 in extension, 8 and 10 mm sockets and if you are lucky to have a 10mm variable bend ratchet wrench, it will be very easy. Good luck, show some pics when you're done.
Old Jan 21, 2013 | 01:16 PM
onehundred80's post #3 in this thread pretty well covers it, although the manual seems to leave out removing the 2 front wheels where is says "Raise and support the vehicle".
PUT IT ON JACK STANDS !!!
This can be accomplished by using the rear jack points and jacking the car high enough to get the stands under the front jack points.
Old Jan 21, 2013 | 06:08 PM
bluecoupe's Avatar
I found that the wheels don't need to be removed and the car doesn't need to be jacked up.
Old Jan 21, 2013 | 06:45 PM
While true, it does however make it a whole lot easier to get to the stuff in the fender well.
Old Jan 21, 2013 | 07:34 PM
depends on age...if you are old like me...jack stands make it easier.... just sayin'...could you read my post? if you can you are young enough to do the job on the ground...
Old Jan 22, 2013 | 01:22 AM
JEFASOLD's Avatar
I do not think that i could remove the splash pan at ground zero, much less everything else. I use 2 Harbor Freight jacks, then put the jackstands under the lower "A" arms and keep the jacks in position for safety plus 4 rear wheel chocks and E-brake. I was an X-ray tech and have seen many tragic incidents of working under cars without proper precautions.
maxcichon
May 14, 2019 07:30 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
rmcdaniel12
Jul 21, 2015 11:35 PM
axnguyen
Jul 21, 2015 11:41 AM
55chevy
Jul 20, 2015 03:08 PM
