Throttle reset?
Old Feb 13, 2013 | 02:56 PM
cjw's Avatar
cjw
Default Throttle reset?
Can someone please post a link to the throttle reset, I for some reason can not find it
Thanks for the help
Old Feb 13, 2013 | 03:50 PM
Mrmiata's Avatar
Default Re: Throttle reset?
You need "the link"?
Or just refresher in instructions?
syfi's Avatar
I'll save you the search....
1. Get in your car
2. Turn the key to the on (not start) position, the position just before the starter
turns over.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back
to the "off" position (don't remove the key), then release the gas
pedal.
5. Wait 2 mins. for a full alignment.
6. Drive the car as you always do.
Old Feb 13, 2013 | 03:51 PM
Perform a throttle reset.
1. Turn the key to the on (not start) position, the position just before the starter turns over.
2. Press the gas pedal to the floor with the key in the "on" position.
3. Hold the pedal to the floor for five seconds, then turn the key back to the "off" position (don't remove the key), then release the gas pedal.
4. Don’t remove the Key. Wait 2 mins. for a full alignment.
Found this in the pdf for 74mm upgrade .....
Old Feb 13, 2013 | 04:42 PM
cjw's Avatar
cjw
Thats what i needed. Thanks guys
Old Feb 13, 2013 | 06:34 PM
It is simple just type 'throttle reset' in the Google custom search and second hit says how to do it. Amazing.
Old Feb 13, 2013 | 07:29 PM
Mrmiata's Avatar
Thank you 180!
And since it's in Engllsh.. I'm off to find a vet..
Old May 10, 2013 | 02:52 AM
GrantB's Avatar
Default
Excellent.
Many thanks Guys.
GB
QUOTE=syfi;724158]I'll save you the search....
1. Get in your car
turns over.
pedal.
6. Drive the car as you always do.[/QUOTE]
Old May 10, 2013 | 11:58 PM
The Beep's Avatar
...or install the Sprint Booster.
rampntlion
21
Feb 11, 2019 08:18 AM
blackpepper
Racing
16
Sep 27, 2015 01:38 AM
atdavis2
Sep 21, 2015 01:25 PM
stelrz1
Sep 21, 2015 11:18 AM
tritongreen
Sep 18, 2015 07:32 AM
