Engine Water Pump life expectancy?
Old Feb 21, 2013 | 10:18 AM
Buggin's Avatar
Default Engine Water Pump life expectancy?
Ok, I'm probably going WAY overboard here... but having the top of the motor and all the stuff in front out, everything is SO easy to get to at this time. I searched through the forums and haven't seen much for engine water pump failures. I'm used to water pumps going around the 100k mark on other cars. So my thought was to just change it while I'm doing all the rest of the crap. I'm at 90k on my SLK32 and would like to go another 90k before having to tear all this crap out again.
Am I just getting crazy with preventative maintenance or do you think it's justifiable to change?
Old Feb 21, 2013 | 10:24 AM
Default Re: Engine Water Pump life expectancy?
Will you kick yourself in the butt if after you put it all together and a few days/weeks/months down the road it goes BAM? This will answer your question.
Old Feb 21, 2013 | 10:44 AM
It's all apart so I say do it.
Look here.
Old Feb 21, 2013 | 10:48 AM
I agree... if you are doing a lot of work, then do it. I usually do hoses at 100,000.
The pump itself is not unreasonably priced and it WILL fail eventually anyway.
Old Feb 21, 2013 | 12:40 PM
latemodel21's Avatar
Default
If you do decide to replace it, make sure the replacement has the extra (previously unused) hole above the alt. This is not found on all original or replacement slk32 water pumps (only 2 of 3 of my slk32s had it).
Chris
Old Feb 21, 2013 | 12:44 PM
Buggin's Avatar
Chris
Ordering on-line doesn't really give me that option... Is the area there, just no hole? If that's the case, I'd just add the hole with a drill press in our machine shop at work.
Old Feb 21, 2013 | 12:59 PM
Default
Picture a starfish born without one of its arms/points... there is nothing to add a hole to.
Do a google image search on slk32 waterpump and you should find a picture.
Chris
Old Feb 21, 2013 | 01:16 PM
tunaglove's Avatar
Just letting you know the cheaper water pumps you see everywhere online only fit the n/a motor. The SRT has different alternator mounts.
Old Feb 21, 2013 | 01:29 PM
Buggin's Avatar
It looks like the Cardone one has the extra mount point. The other "off-brands" do not. I wouldn't mess with the cheap ones anyways. This part number is specifically listed to only fit SLK32, C32 and SRT-6:
Product Detail
You can get it from Partsgeek for $101 but they wont ship to my APO box. The best I can find that will ship it is $200 from Amazon.
Old Feb 21, 2013 | 05:43 PM
stryfox's Avatar
I had a defective unit in my limited. it failed at around 20,000 miles.
it did not leaf but was making noise, when i took it apart the impeller shaft was bad.
If Ialready had it apart I would replaced it with a quality replacement.
Old Feb 21, 2013 | 11:36 PM
Product Detail
Shame you can't get someone in your unit that is stateside (or a family member) that can have it delivered to them and just forwarded (or reshipped) to you there.
Old Feb 22, 2013 | 01:21 AM
Product Detail
the difference is pretty big there.
Alan, I still feel like I still owe you a favor for your involvement in the Wavetrac GB . If you like, I could order that pump for you and then then send it to your APO.
Chris
Old Feb 22, 2013 | 01:33 AM
Buggin's Avatar
I appreciate the offer, and yes, I usually ship things to my buddy and he reships via USPS to me. However, that takes about a week longer usually and I'm ready to start reassembling now... Amazon has a special deal with customs so I can get direct from them to my door in a week, sometimes less.
FWIW, my buddy checked his local area in MA for the pump. He owns a transmission repair shop and gets wholesale discounts and couldn't get the same pump cheaper than $180. Not sure how partsgeek has a "new" pump for $100 with no core charge.
Old Feb 22, 2013 | 11:04 AM
I never bothered to read the earlier posts here but the NA and SRT use different pumps as you know, the SRT has the oil cooler outlet on it for one thing. Some places do not know this and quote the same pump for both. I am not sure if it's true in this case but does happen. The NA pump is about $100 or so give or take. The SRT pump costs twice as much or more.
Old Feb 22, 2013 | 02:04 PM
Buggin's Avatar
The Cardone website breaks them out with different part numbers for the SLK32 vs SLK320 (n/a). That's why I ordered by part number instead of by vehicle. I'll let you guys know how it goes and if the Cardone Select 55-83333 is correct and has the extra mount location.
Old Mar 6, 2013 | 11:37 AM
Buggin's Avatar
For info:
Cardone Select part# 55-83333 is the correct pump for the SLK32/SRT-6 and can be found for around $100 from partsgeek.com
2 things to note:
1 - If you are mounting a pulley in the unused hole above the alternator, ensure you drill it out before mounting to the correct size for your bolt PRIOR to mounting... (only applies to people with PSK setups)
2 - the 2 holes at the top, which the black bracket screw onto, may need to be tapped. Mine had non-threaded holes. You will also want to do this prior to mounting.
Other than that, it is a perfect match. It's also brand new and not a reman.
Cheers,
~ Alan
Old Mar 6, 2013 | 12:08 PM
For info:
2 things to note:
Cheers,
~ Alan
Strange thing is that PartsGeek has the NA pump listed as $107.25 which is six bucks more than their SRT pump.
The SRT pump has the oil cooler hole drilled out.
The NA price is about right for these pumps but the Cardone price for the SRT is at least $90 cheaper than elsewhere
Old Mar 6, 2013 | 12:48 PM
tunaglove's Avatar
Default
For info:
2 things to note:
Cheers,
~ Alan
Thanks man!! You just saved me $90.
Old Mar 6, 2013 | 01:59 PM
Buggin's Avatar
I was just trying to clear up the confusion of "the cheap pump is for the N/A" statement I've seen in several threads and provide people with a known good part #. The best way to get the right part is to order by part #.
Glad to give back to this forum when I can!
Old Mar 8, 2013 | 11:21 AM
Buggin's Avatar
I almost forgot to mention. This pump comes with a new rubber gasket and a flat gasket.
As the stock pump only used the rubber gasket, I didn't add the flat gasket.
Kodebuster
Nov 5, 2020 04:06 PM
PimpDaddy
Mar 31, 2020 07:22 PM
BrenLW
Aug 5, 2015 04:53 AM
Tp'sfury
Jul 17, 2015 01:15 PM
