Low on coolant
Old Mar 25, 2013 | 01:13 PM
ModlessG's Avatar
Default Low on coolant
I didn't find a leak ,but I'm down just over a quart of coolant ? Ideas? thanks
Old Mar 25, 2013 | 01:39 PM
Thirteendog's Avatar
Default Re: Low on coolant
You may have a cracked intercooler
Old Mar 25, 2013 | 01:43 PM
Easley15's Avatar
Did you check your engine oil to see if there is a leak inside the engine? The oil would normally be greyish color if it leaked in there
Old Mar 25, 2013 | 02:23 PM
ModlessG's Avatar
Thanks I will check the oil.I was thinking it may be the inter cooler .any other ways to check this ? It looks like Needswings has a replacement now.
Old Mar 25, 2013 | 02:29 PM
ModlessG's Avatar
the oil is dirty as its due for a change been almost 5000 miles. Normal level not over full or anything.Looks like normal dirty oil to me.
Old Mar 25, 2013 | 02:38 PM
Easley15's Avatar
I'd wait for the more seasoned guys to come and answer :/ my knoledge stops there
Old Mar 25, 2013 | 02:57 PM
Without taking the mani's I don't think so. I believe that's where John (JHM2K) noticed it.
Old Mar 25, 2013 | 04:05 PM
Bigkid's Avatar
I had a small slow leak from a coolant hose that did not show up on my grage floor. The coolant was collecting on the splash guard and then draining as I drove up the driveway. Check the splash shield, you may be lucky.
If it is the IC needswings has the oem replacement and a gasket kit for installation. Rudy is offering an aftermarket version. Good luck.
minimayhem
16
Aug 23, 2016 07:47 AM
Darryl Camisa
Oct 7, 2015 07:10 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
suelo
Sep 18, 2015 05:01 PM
