Ic Pump for SRT six
Old May 14, 2013 | 11:03 PM
Djo's Avatar
Djo
Default Ic Pump for SRT six
Went to independent Mercedes mechanic. Told me Bosh made one for Mercedes cost $360 without installation Told me the reason price was the Mercedes icy pump was made with superior materials by Bosch. Wants another 200 put it in
Old May 15, 2013 | 01:20 AM
syfi's Avatar
Default Re: Ic Pump for SRT six
Here's a great price for the same updated Bosch model 10 pump your mechanic is referring to...w/ free ship. Same place I got mine!
Mercedes Auxiliary Water Pump - Bosch (OEM) 0392022010 | FCP Euro
Here's a link that shows the steps for removal of the pump. Even though this is for the Johnson CM30 swap, just unplug the old Bosch and install/plug in the newer Bosch 10. No need to cut the plug as you would with the CM30 install. Simple plug & play. You can pretty much DIY or just show a reputable mechanic the pics and he should be able to do the swap in no time for a decent price.
https://www.crossfireforum.org/forum...on-ic-pump.pdf
If you are mechanically inclined and have access to the right tools, you can do it yourself for under $100 !!!
Old May 15, 2013 | 09:32 PM
I would never go to that mechanic again....
Old May 18, 2013 | 07:52 PM
musicnsurf's Avatar
I bought two from Autohaus in AZ. Black one was bad (about 1/2 cracked off) and the graphite for preventative maintenance (turns out it was fine). Took me about an hour and was careful not to leak any fluid, so no need to burp the system. This is an easy fix if you're even slightly mechanically inclined.
Old May 18, 2013 | 09:56 PM
Bosch Intercooler Fluid Pump
here is the pump for 129 with the wiring harness which you will need, so get it from our friend and he owns a srt6 ,get to know Needswings now. sounds like you need him. jim
Old May 18, 2013 | 11:18 PM
syfi's Avatar
Not knocking Needswings but they can be exorbitantly high on some items. With shipping you'll be paying over $150 for their pump which doesn't state if it's the updated Bosch or the original OEM replacement. And I didn't need the harness when I replaced mine. Save yourself over $50 for the FCP Euro one @ $96.95 w/ free ship, which is definitely the updated Bosch #10.
Heck, the money I saved buying the FCP one payed for my Jones "X-pipe" ($45.00) and still saved money!
http://performance-curve.com/2stainl...elxpipe-1.aspx
Old May 23, 2013 | 12:45 PM
2.25" Stainless Steel X Pipe
Thanks for the tip, I have just received mine, $130 shipped to Canada.
I'm replacing the OEM one before it crashes and burns.
I have a used Johnson pump as a spare as well but I decided to go with the newer Bosch
model.
The NeedsWings pump is the same model as this one.
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
Beeker
Jul 20, 2015 03:46 PM
Tp'sfury
Jul 17, 2015 01:15 PM
ja.nko
Jul 10, 2015 03:21 PM
