problem ignition key locked
Old Jun 17, 2013 | 03:49 PM
blueeyes147's Avatar
Default problem ignition key locked
hello to everyone as have problem in the title key ignition locked, even in my old crossfire N / A was faulty but after a little bit of effort I could get it started turning, now in my srt 6 is blocked completely the key does not want to rotate, and the 'car does not turn on, it was completely blocked you ever? how did you solve?
Old Jun 17, 2013 | 04:04 PM
RL67037's Avatar
Default Re: problem ignition key locked
Do a search for "sticky key" and that should give you a thread on what you need to do.
Good luck!!
RL
Old Jun 17, 2013 | 04:07 PM
Good luck!!
RL
can you get me a link??i m italian not expert of this forum
Old Jun 17, 2013 | 04:13 PM
RL67037's Avatar
See if this helps. I'm working from my phone so I'm not sure how the link will work.
https://www.crossfireforum.org/forum...ad.php?t=33074
RL
Old Jun 17, 2013 | 04:14 PM
RL67037's Avatar
If that doesn't work, try this:
RL
Old Jun 17, 2013 | 04:19 PM
works thanks! thank you very much
Old Jun 17, 2013 | 05:09 PM
Go straight to the PDF file, down load it and print it.
PDF file (click)
Old Jun 21, 2013 | 02:36 PM
some of you makes me the kindness to find a text file where is written the same as the pdf? because in pdf I can not translate it with google translate and tomorrow I have to take it to my mechanic I still have the car locked and disassembled help me thanks
Old Jun 21, 2013 | 03:53 PM
Text file OK? No pictures.
File Type: txt
Old Jun 21, 2013 | 04:18 PM
from the tablet does not open it, as soon as I get home I try from the computer thanks
Old Jun 21, 2013 | 04:38 PM
cmz's Avatar
cmz
bona fortuna
Old Jun 22, 2013 | 08:31 AM
Default
problem solved I spent 100 euro for the hours of work to the mechanic, thanks to your help was crucial
Old Jun 22, 2013 | 09:22 AM
Special thanks to onehundred80
Old Jun 22, 2013 | 12:22 PM
I'll bet it wouldhave been about 500 euros at the dealer because they would assume it needed a new assembly.
Old Jun 22, 2013 | 02:15 PM
Luckily I brought from Chrysler dealer otherwise asking me a lot of money!but the crossfire is not known even by Chrysler dealers in Italy, I asked and they said they haven't sold even one
REYMARTZ
22
Aug 7, 2021 12:37 PM
jhansen
21
Feb 15, 2017 04:26 PM
scheper
Aug 3, 2015 03:13 PM
gtjl
17
Jul 22, 2015 06:28 PM
66L72M21
Jul 15, 2015 04:23 PM
