Adjustable tunes
Old Aug 11, 2013 | 04:43 PM
blackpepper's Avatar
Default Adjustable tunes
A local performance recently scanned my car an showed me I was in need of sparkplugs or wires ,plugs were changed at 50k cwr has 62k stock wires,anyhow last week I had the guy take 5% fuel from across the board took the 6 to the track and my traps were slower he added 5% back my trapspeed came back,this scanner he has got the ability to make small changes to a tune.So to me since I am in process of adding a small 55 shot of nitrous to the car taking two degrees of timing out the computer is the norm,this would be free since me and this guy have been friends for a while,if so this would be a lot cheaper than sending the computer back to inmotion,any opinions.
Old Aug 11, 2013 | 04:52 PM
grip grip's Avatar
Default Re: Adjustable tunes
What device is he using (SCT, Trinity, etc) or is he connecting his computer? I'd kill to be able to make changes to the timing and fuel myself.
Old Aug 11, 2013 | 04:56 PM
grip grip's Avatar
Since we're on the topic of nitrous (sort of), I figured I'd mention I just got back from making a few runs on the street with the new all season tires. The tires held the 75 shot at 4,200 RPM's in first gear. I still got a tiny bit of spin when it hit, so I didn't get greedy.
Old Aug 11, 2013 | 06:21 PM
I will find out exactly what device its pretty large say a 10 inch by 10 inch screen he use it on audis bimmers and mercs at his shop,it actually read the mutliple small misfires I was getting at idle it didnt throw any codes he said it could be the the wires since they have 60k on them,he added 5% fuel on top of the inmotion tune and at wide open throttle this scanner indicates my a/f ratio is about 11.6 across the board I still think a wideband is better.The gentleman running the 75 shot are you stock or modded and where or you spraying before or after the charger,I 'm leaning towards before the charger.
Old Aug 11, 2013 | 06:27 PM
grip grip's Avatar
I think there's a link to my nitrous write-up in my signature.
EDIT: Guess not. I'll find it and post the link.
Old Aug 11, 2013 | 06:28 PM
grip grip's Avatar
Here you go:
https://www.crossfireforum.org/forum...t-nitrous.html
Old Aug 11, 2013 | 06:30 PM
No need I still have pictures of your setup you have the zex kit did you adjust your timing.Also I may have a answer about the scanner I left my buddy a voicemail,soon as I get that information I will post it.
Old Aug 11, 2013 | 06:44 PM
grip grip's Avatar
I retard the timing 2 degrees for the 75 shot and I spray in the intake tube, pre-supercharger.
Old Aug 11, 2013 | 07:15 PM
grip grip's Avatar
Is this it?
Old Aug 11, 2013 | 07:47 PM
That really looks close but it has handles on each end
Old Aug 11, 2013 | 07:48 PM
His device is actually square in shape.
Old Aug 11, 2013 | 08:08 PM
grip grip's Avatar
That's nice to hear. Hopefully it's able to make adjustments to Open Loop fuel trims and timing as well as closed loop. If it's Closed Loop changes only, that wouldn't be as helpful in fine-tuning at the track.
Old Aug 11, 2013 | 08:14 PM
grip grip's Avatar
Your description reminds me of the Bully Dog.
Old Aug 11, 2013 | 08:50 PM
Sorry it took a minute to reply actually at wrk just went on a break,its larger than a bullydogg an really just looking at it,its a manufacturers tool,I did see him used this same scanner on my 04 silverado truck,the dealership couldnt find out why my truck was putting itself in neutral,well he save me a ton of money with his scanner he can manually command sensors with this scanner I had a bad transfer case switch 40$ instead of the tansfer case the stealership said I needed.
Old Aug 12, 2013 | 06:17 AM
ImportLabSRT's Avatar
What color is it? It sounds like he just has a scan tool like the Snap-On Modis or OTC Pegisys. If that is the case, all he is doing is reading information from the OBD-II port. Even if it was a Star-DAS, there is not any fueling adjustments that can be made. He would need software like WinOLS and the DAMOS file for the Bosch ME 2.7/8 and the maps defined to make fueling adjustments.
Old Aug 12, 2013 | 08:13 AM
I am pretty sure he has some software becuase he took 5% fuel away from my crossfire even though I have a inmotion tune my a/f was something like12.1 the car didnt like that but its gray in color but I will have the type an software he has after 9 oclock after he open I called him several times he was probably out fishing yesterday.
Old Aug 12, 2013 | 08:41 AM
Do you have a SRT-6? 12.1 is pretty lean on pump gas.
Old Aug 12, 2013 | 09:16 AM
I have a modded 6,he has a mercedes scantool with some type of DAS software
Old Aug 12, 2013 | 10:41 AM
grip grip's Avatar
Durn
Apr 28, 2016 02:04 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
brandoni
Sep 30, 2015 07:48 PM
Sep 28, 2015 07:40 PM
