Will a Needswings DCAI for an NA fit an SRT?
Old Nov 3, 2013 | 12:17 PM
vinnys's Avatar
Default Will a Needswings DCAI for an NA fit an SRT?
I looked at a few of both, but not side by side. Looks like if you remove the bottom piece from the Na it will fit on the SRT TB. Anybody know. I don't belive that the silicone y is different. Thanks
Old Nov 3, 2013 | 08:53 PM
itsky's Avatar
Default Re: Will a Needswings DCAI for an NA fit an SRT?
No, not to my knowledge. The NA CAI has a spot for the MAF where the SRT-6 one does not.
Old Nov 3, 2013 | 10:04 PM
vinnys's Avatar
I know, but by removing that piece from the silicone y, will it work?
Old Nov 4, 2013 | 01:46 AM
itsky's Avatar
Unless the design has changed, the MAF is not in the silicon part.
Old Nov 4, 2013 | 08:36 AM
vinnys's Avatar
Correct. The MAF is in the piece that's CONNECTED to the y. I'm thinking that if you remove that piece, the y should go right on the SRT's TB.
Old Nov 4, 2013 | 04:57 PM
NeedsWings's Avatar
they are not interchangeable without welding and recoating
Old Nov 4, 2013 | 06:30 PM
vinnys's Avatar
You will need to add a port for the breather, correct?
Old Nov 24, 2013 | 03:39 PM
vinnys's Avatar
Is the silicone Y the same on both? Could anybody do a side by side?
maxcichon
May 14, 2019 07:30 PM
4drturbo
Jan 3, 2019 02:46 PM
UNDER PSI
Jul 18, 2015 02:12 PM
Zoodust
Jul 16, 2015 06:17 PM
bradleykologek
Jul 6, 2015 02:49 PM
