Need some help from the "Mod" Squad. (Tech. guys)
Old Nov 27, 2013 | 07:31 PM
Mr. Max's Avatar
Default Need some help from the "Mod" Squad. (Tech. guys)
Took the SRT6 to the stealership because of the engine light. They told me a rat had eaten my exhaust gas sensor wiring. That was very believable. However, they told me it that it shorted out the engine management relay and it needed to be replaced. That I was skeptical of. I picked up the car with no work done. Hell, I can fix it for 1/4 of the $1200 they wanted. I haven't slid under the car yet but I checked all the fuses in the E.M. relay and they are all good. I also noticed on the paperwork they used "recommended", not "required" like they did on the 02 sensor.
Before I order any parts, I wanted to get some feedback from you guys. What's your take. Thanks
Old Nov 27, 2013 | 10:30 PM
Mrmiata's Avatar
Default Re: Need some help from the "Mod" Squad. (Tech. guys)
Replace the 02 sensor and see what you got... that would be my course of action..
Old Nov 27, 2013 | 11:29 PM
Mr. Max's Avatar
Good call Mrmiata, I just ordered an O.E. Bosch from Amazon for 73 bucks after taxes. I'm betting this will solve the problem.
Old Nov 27, 2013 | 11:40 PM
grip grip's Avatar
Don't forget this:
Powerbuilt 648691 Oxygen Sensor Offset Puller
Powerbuilt 648691 Oxygen Sensor Offset Puller : Amazon.com : Automotive Powerbuilt 648691 Oxygen Sensor Offset Puller : Amazon.com : Automotive
Old Nov 28, 2013 | 12:09 AM
Mr. Max's Avatar
Thank you my friend you saved me some time and hassle. I'll order one now.
Old Nov 28, 2013 | 12:11 AM
As long as the damage was before the pigtail connector...
Old Nov 28, 2013 | 12:16 AM
Mr. Max's Avatar
Going to the sensor James or coming from it? In other words which side of the pigtail is "before" ?
Old Nov 28, 2013 | 01:16 AM
MoparFreak69's Avatar
Between the sensor and the connector where it joins the main harness. If it is damaged above that then some repair work is going to be required.
Old Nov 28, 2013 | 02:36 AM
Mr. Max's Avatar
Thanks Mopar Freak, I appreciate the input.
Old Nov 28, 2013 | 05:24 AM
pjm30144's Avatar
I agree with these guys and bet this will solve the issue.
Old Nov 28, 2013 | 02:57 PM
Mr. Max's Avatar
Just to be on the safe side I ordered a new OEM relay on Ebay. It was only $200.00. I drive from L.A. To Vegas a lot on business. Sometimes coming back after midnight. It's worth $200.00 just to have piece of mind. I think the sensor and the relay ought to get that damned "check engine" light off. A few rat traps wouldn't hurt either. I live in the foothills and those little F*****s are hell on cars. I had 10 guage cable that went straight to the battery on my Jag. Filthy rodent got a big surprise when he bit into that. It didn't take CSI to figure out what happened.
Old Nov 28, 2013 | 05:51 PM
arejohn's Avatar
Did I miss reading the code?
Old Nov 28, 2013 | 07:55 PM
NeedsWings's Avatar
Don't forget this:
or a 22mm wrench
Old Nov 28, 2013 | 08:14 PM
Mrmiata's Avatar
Mouse chewed wires.. kinda a generic code.. Good call that's where at least one problem is..
Old Nov 29, 2013 | 12:56 AM
Mr. Max's Avatar
Yes arejohn you did. However, since you brought it up will a regular OBD II code reader read these things? I heard that they won't and the one that will is prohibitively expensive. The dealer used one so they are either tellin' the truth or bullshitting me. I will know which in short order. Enlighten me on the reader.
Dec 11, 2015 09:41 AM
o55ie18
Oct 5, 2015 05:50 PM
thatcham
Oct 5, 2015 02:41 PM
leaddog2015
Sep 26, 2015 08:23 PM
rmcdaniel12
Sep 21, 2015 10:58 AM
