Dyno ?, Numbers don't add up
Old Jan 2, 2014 | 12:32 PM
meh03's Avatar
Default Dyno ?, Numbers don't add up
So after looking at different dyno graphs, websites, posts, etc. the numbers aren't adding up.
If you go to EC their dyno shows 282 stock, 328 after 65mm pulley & tune. Makes sense.
NW is saying about 30hp for the CAI. You look at their dyno for their custom intakes and the number is 316hp before the intakes (with ASP pulley, CAI, tune). Then 360+ with the intakes. Shouldn't they be around 358hp before the intakes and over 400 with. That's a big difference. What am I missing? If 360hp is the right number then something along the line isn't adding what it claims to add.
I realize different dynos, but something is off...
Old Jan 2, 2014 | 12:51 PM
sk8erjosh09's Avatar
Default Re: Dyno ?, Numbers don't add up
That 282whp stock seems low. I've seen graphs of SL500's pull that stock on dynojet's and their rated 30+ crank hp lower.
I bet EC was on a dyno that reads low like a and Needswings was on one that reads high.
Old Jan 2, 2014 | 01:22 PM
FUBU's Avatar
different dynos different number different cars different mods. soooo many factors.
Adam has all mods available and get 366 rwhp. a e55 amg got 360 rwhp on same dyno. e55 had new pump and some other small air intake mod.
Padgett's Avatar
Also there are many different ways of measuring horsepower (SAE gross and net, rear wheel, EU likes KW, and most are fudged to some extent such as corrections to STP (standard temperature and pressure).
When quoting numbers it is important to also say what the parameters used were else they have little meaning.
I prefer torque curves anyway, the area under the curve tells more about acceleration potential.
Old Jan 2, 2014 | 01:33 PM
That is weird. E55's are rated stock crank at 469.. That's more than 23% drivetrain loss. That puts the SRT at 470+ at the crank. That seems pretty damn high without spray.
EDIT: Thinking about it, 366rwhp for a heavily modded SRT doesn't seem that high, nvm. 360 for a 55 definitely seems low though.
Old Jan 2, 2014 | 01:45 PM
Padgett's Avatar
I used to figure about a 30% loss between gross and net, both are measured at the crank. I'd figure at least another 10-15% to RWHP but then everything has "correction factors".
Even back in the Toledo days a good operator could add "Kentucky windage" to the readings used to say the only way a F*rd 390 made 300 hp was to crank it wide open, dump in the load, and see how far the needle swung.
This is a small one. Those in the GM dyno lab were a lot bigger. And green.
Old Jan 2, 2014 | 02:15 PM
If the numbers dont' add up, use different numbers.
You know, like the gov't does.
Old Jan 2, 2014 | 02:33 PM
Mrmiata's Avatar
We really need one of those "LIKE" buttons!
Old Jan 2, 2014 | 02:35 PM
Thirteendog's Avatar
You guys are always looking for different ways to measure your dicks.
Old Jan 2, 2014 | 02:54 PM
Mrmiata's Avatar
Ha.. I just use the old seat of the pants and squeal factor myself..
Old Jan 2, 2014 | 04:04 PM
JHM2K's Avatar
Why do you think Canadians use centimeters?
Old Jan 2, 2014 | 04:24 PM
grip grip's Avatar
Old Jan 2, 2014 | 04:35 PM
Mrmiata's Avatar
Looks like American Indian corn there!
Old Jan 2, 2014 | 04:36 PM
Old Jan 2, 2014 | 04:59 PM
Rachel Ray - proof that guys can go nuts over a woman who is NOT a size 1 !
Old Jan 3, 2014 | 11:25 AM
arejohn's Avatar
These dynos measure time and RPMs. Everything else is somebody's arithmetic. Best for before and after runs.
Old Jan 3, 2014 | 12:12 PM
JHM2K's Avatar
Amen to that! Kim is a size 0 at Express
Old Jan 3, 2014 | 12:24 PM
Mrmiata's Avatar
Size 0?
As in 0MG?
Old Jan 3, 2014 | 02:05 PM
JHM2K's Avatar
Originally Posted by Mrmiata
Size 0?
As in 0MG?
As in, 32-25-34
So yes, 0MG
Old Jan 3, 2014 | 06:14 PM
As in, 32-25-34
So yes, 0MG
