Startech 4.4s
Old Jan 17, 2014 | 11:05 AM
Mr.Newton's Avatar
Default edit
edit edit edit
Old Jan 17, 2014 | 12:13 PM
S. Artee's Avatar
Default Re: Startech 4.4s
Very exciting! Looking forward to updates.
Old Jan 17, 2014 | 12:22 PM
JHM2K's Avatar
This thing isn't even completed, and it's already my favorite Crossfire.
NICE!!!!
Old Jan 17, 2014 | 12:52 PM
FUBU's Avatar
Want to buy my koni dampers? Used 100 km. ?
Old Jan 18, 2014 | 12:56 PM
Billy22Bob's Avatar
On first read......drool.....
Amazing that you can access all that stuff and it all looks..... so....neat.....
I'm guessing this is based upon the 96.8mm bore E37, but with what seems to be a 100mm stroke? (stock E37=84mm) - I think that means proportionaly more power but maybe not so much more torque.
However, that sucker will be wanting to be fed some serious air, did you ever consider the SL55 supercharger on it?
No mention of a DCAI?
.....change - previous calcs under review....
will repost shortly....
Old Jan 18, 2014 | 04:41 PM
Mr.Newton's Avatar
Hey,
thanks for your detailed information.
At first I will go with the stock 74mm sc pulley and see how it works, possible to go smaller with a 68mm or 65mm one, depends on the efficiency of the supercharger.
I´ve already stage 2 in my mind- modified AMG 55 supercharger ;-)
btw: bore: 99,5mm stroke: 93mm
Old Jan 18, 2014 | 06:27 PM
sk8erjosh09's Avatar
Holy Geez...
Old Jan 20, 2014 | 07:05 AM
Billy22Bob's Avatar
Had a bit of a recalc.
Asuming you've taken care of compression ratio considerations......
I admire the intent and the challenge, As we say here - you lucky, lucky *******....
.... however....
I think you'll find you'll only get about 6psi boost and 600cfm capability = horse power - with the 74mm/155. That's is similar to a stock setup SRT6/SLK32 at 14.5psi and 610cfm.
Due to the larger engine volume you won't be hitting pressure ratio (heat) issues with the stock IHI S105 1.4L SC - so can I talk you into considering a 181 crank straight up* (with all the requisite underdrive pulleys). That should yield you nearer10psi and 720cfm...now you're starting to talk some serious hp (>410).
After enjoying that for a while, then you can slip on the 65 for13psi ~830cfm
You can leave it at that unless you're going to drive the SC to destruction (17,516 rpm) with a 181/62mm setup for a neat 14psi and 870cfm +++ over 500 bhp.
Awesome - Good times and Good luck!
rayth
41
Jul 31, 2019 04:02 PM
Nezek
Oct 10, 2008 12:15 PM
MAYAman
Apr 23, 2007 10:37 PM
mbepic
Mar 10, 2005 12:54 PM
Dan Root
Jun 4, 2004 11:28 PM
