Intercooler tank
Old Feb 12, 2014 | 01:56 PM
Default Intercooler tank
I have a separated coolant system and I would like to add a separate tank for the IC. What is the nicest looking tank? Any ideas for me?
I guess I just have to 'T' this into a hose to the pump , yes?
Old Feb 12, 2014 | 06:10 PM
amgstyle's Avatar
Default Re: Intercooler tank
I am also looking for a good separate ic tank as well. any info would be great
Old Feb 12, 2014 | 08:04 PM
itsky's Avatar
PM rmaier. I do believe he has a nice setup for this.
Old Feb 12, 2014 | 09:05 PM
hustler316's Avatar
Like this one
Old Feb 12, 2014 | 10:39 PM
Originally Posted by hustler316
Like this one
I like that one, it is not obvious you even have one.
Old Feb 12, 2014 | 11:06 PM
hustler316's Avatar
LOL yes it's cleverly hidden in the stock battery location
Old Feb 13, 2014 | 09:38 AM
boostmonkey's Avatar
There is this setup:
https://www.crossfireforum.org/forum...e-tanks-3.html
Old Feb 13, 2014 | 10:16 AM
Er .... there is a picture missing.
Old Feb 13, 2014 | 02:14 PM
I saw a power steeing from (I think it was a BMW ) mounted next the radiator this is one that the pump is not in the reservior,, I think it was 1 1/2 qt. with the screw type cap on top you have a place to fill and check it. what do you think of that? jim
Old Feb 13, 2014 | 02:23 PM
dinasrt's Avatar
Here is the BMW- PS tank version
Old Feb 13, 2014 | 03:00 PM
velociabstract's Avatar
I used the BMW power steering reservoir as an intercooler tank back when I had a leaking intercooler. The boost would pump water into the circuit and I'd spray water out the top. I have no tank at this time.
Les
Old Feb 13, 2014 | 05:20 PM
dinasrt's Avatar
Les
What's good about that is the easy diagnosis it provides us now that we know what to look for. I'm always checking the vented cap area after hot laps to see if my time has come for the failure. Saving up for Rudys CAC.
Old Feb 13, 2014 | 05:29 PM
I won't edit the my prior post but what I meant and I think you understood is that under high sustained boost, air enters the intercooler circuit. Under low boost water enters the manifolds. At least on a separated circuit with a non pressurized reservoir.
Les
Old Feb 13, 2014 | 05:45 PM
dinasrt's Avatar
Thanks Les. Yes; understood. I'm curious why you don't have a separate fill tank anymore.
Old Feb 13, 2014 | 06:23 PM
That looks good, I'll look into that. Thanks.
Old Feb 13, 2014 | 06:33 PM
I've been down a long and winding road. I went back to the stock heat exchanger and reservoir for racing points reasons. The result was spraying the engine compartment and knowing I had to change the leaking intercooler. Done. Also the stock heat exchanger IS too small for "all the bolt ons". I have an E55AMG heat exchanger at this time for engine coolant temperature reasons. The super sized H/E elevates the EGT's about 3º. Not much but when your too hot. Well, out it came. What I like about the interconnected system is it's pressurized. It doesn't seem to affect my I/C coolant temperatures. With the separated circuits and connected circuits the maximum IAT temperatures on the road course are the same as far as I can tell. Since they reach 180º and max timing is pulled at around 140º, or so I've read, no way I can keep them that low. So no gain for me with a super sized cooler. I'm not done messing around with it though.
Les
Old Feb 13, 2014 | 06:38 PM
BTW, heres the picture of Justins reservoir.
Old Feb 13, 2014 | 08:36 PM
I know it looks dirty but the paint peels off because it gets so cold,this is a 3 1/2 gal. tank.jim
Old Feb 13, 2014 | 08:41 PM
I hate to think about plumbing in a separate tank, but I think after running the 1/2 mile event and seeing Jake's ice tank in the trunk and how well it worked it is tempting. Dave why are you wanting a separate tank? More volume?
Old Feb 16, 2014 | 11:45 PM
ckovach's Avatar
I used a Meziere 28-oz tank.
Meziere Enterprises
