Stacked Pulleys & Fuel Injectors
Here is my most recent log snipped from a hard highway run out of a gas station.
Maybe not as relevant since this is from a C32 but it's a data point. I run OEM C32 fuel pump, looped fuel rail with 6AN fittings, 550cc injectors, 164mm crank pulley and 65mm SC pulley, NW 3" dual air intake and a 80mm TB. The interesting part is the readings for the fuel pressure and the injector duty cycle. I tried the 164mm with the 62mm pulley but would "run into the wall" on occasion, and therefore downgraded to the 65mm SC pulley.
The fuel pressure graph doesn't show much detail, but it looks like your fuel pressure is dropping under WOT as well. What is the fuel pressure supposed to be on a C32 AMG? What does it read at idle? The AFR stays high even when the IDC starts climbing again which indicates the fuel pump is not keeping up also.
My recommendation is that you upgrade the fuel pump AND have the ECU retuned.
Lenin, I think you have a problem. You are leaing out from around 5500 RPM up, which is a very dangerous thing. The injector duty cycle ramps up to 100%, then drops down - causing your AFR to go lean. That is something in the tune that needs fixed.
Update: The stock fuel injectors were not sufficient for the stacked 178 and 65 pulleys. I had to be out of town, but I gave IPS Motorsports (shop with dyno here in Ohio) the liberty to adjust the fuel pressure as needed and as directed by Eurocharged. They said they cranked it up until it was very rich down low but it was still running lean on the top end. They installed Bosch 550cc injectors and all is great now!
