Raised RPM Limiter
Old Feb 21, 2014 | 02:55 PM
Guran's Avatar
Default Raised RPM Limiter
What is the benefit of changing shift point and raised rpm limiter on our engine ?
Old Feb 21, 2014 | 04:26 PM
Default Re: Raised RPM Limiter
Obviously more RPM's quals more available HP. Assuming the tuner keeps the torque curve aligned.
Higher shift points lets one goe farther accelerating in thelower gears, puttingmore of the HP to the wheels.
Our engines are limited by engineering to conserve them and extend life span. They are overbuilt and can standd being driven closer to their design limits. It is up to the driver to control his urges and keep things within range. But the limiter can be raised safely to say 6300 RPMs without issues.
Have a tuner like Eurocharged do it for best, safest results. They can make the limiter different for different gears and change shift points to match and optinmize performance.
I have a manual tranny and even there, they set the rev limiter different depending on the gear I am in.
Old Feb 21, 2014 | 05:24 PM
velociabstract's Avatar
With a SRT-6 you'll see around 20 hp increase reving to 6400 with mods similar to mine. It's necessary to raise the TCU limiter at the same time or you'll hit the TCU rev limiter at 6100 more or less.
Les
Old Feb 21, 2014 | 05:44 PM
Nothing worse than hitting that null space when the TCU says "uh-uh! Nope not gonna do that."
Old Feb 22, 2014 | 02:52 AM
Guran's Avatar
OK, thanks
Old Feb 22, 2014 | 05:28 AM
Silverarrow's Avatar
Originally Posted by Guran
OK, thanks
Hi Göran,
I have raised my RPM limiter to 6800rpm and gained about 20whp
Nov 11, 2015 05:22 AM
Reliableron
Oct 17, 2015 10:19 PM
Jocko124
Sep 29, 2015 11:39 AM
xfireon20z
Sep 10, 2015 04:27 PM
Jocko124
Sep 5, 2015 09:10 PM
