AFR Question
Old Apr 23, 2014 | 08:24 PM
TommyT's Avatar
Default Re: AFR Question
To answer the original question.....its fine. on ANY vehicle tip in will always show a lean spike and then drop down to an acceptable level. The fuel has to catch up.
Old Apr 23, 2014 | 09:03 PM
Speedy4x4's Avatar
Default
Originally Posted by meh03
A standard engine should be around 14:1, ours should be around 12.5:1
In naturally aspirated engines powered by octane, maximum power is frequently reached at AFRs ranging from 12.5 to 13.3:1.
So since our engines are more efficient wouldn't a slight leaner mixture reading at the exhaust be OK.
plus the area a person lives/drives in can vary the AFR due to high/low moisture putting higher/lower O2 pushing in exhaust
Old Apr 24, 2014 | 02:19 PM
Billy22Bob's Avatar
Using narrowband sensors to read afrs at wot is risky, they are not very accurate at anything higher or lower than stoich.
Has anyone found a wideband and smarts unit for our ECU's that outputs a "still compliant" 0-1V signal to the ECU and a 0-5V to a separate cockpit gauge?
Old Apr 24, 2014 | 03:26 PM
boostmonkey's Avatar
Don't they all? My Innovate LC-1 has a simulated narrowband output built-in. I have never used it. I welded in a new bung on each down pipe to be able to install the WBO2 into either side.
Old Apr 24, 2014 | 05:17 PM
tunaglove's Avatar
Default
I tried with a plx wideband before I had a bung welded into the downpipe. It worked ok for a little while, but then started to get an o2 sensor heater code. I also tried to get closed loop enrichment under boost with a Split Second enricher device and could not get it to fool the ecu. Even stumped the techs at SS. The guy who put the Rotex in his NA could not get the Aem piggyback to simulate the narrowbands correctly either. There is something funky about the way this ecu uses the sensors......
Old May 26, 2014 | 09:13 PM
meh03's Avatar
Yeah, that's what I'm afraid of. I trusted the EC tune with only a single CAI and 65mm pulley and just checked it recently. When I saw those numbers it scared me. Have not driven it much since to evaluate further. I will check any tune going forward! My long term fuel trim was something like +4.
So I installed the SL55 pump and new filter today drove it for a little while and my long term fuel trim is 0.78. Guess it worked.
Yes the fuel line clips were trouble until I figured out how to get them off.
Yes the lines were stuck on and a *****.
Tried to clamp the lines, failed. Nice gas bath.
Think she is ready for me to install the NW manis
Old May 26, 2014 | 09:25 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Did you install the adjustable pressure regulator?
Old May 27, 2014 | 09:24 AM
meh03's Avatar
No, stayed with the stock replacement filter.
Old May 27, 2014 | 03:06 PM
Billy22Bob's Avatar
This is a somewhat lazy post......'cause I didn't want to troll through all the history...
1) So how does 0.78 compare to your pre-SL55 figures?
2) without trying to reopen a can of worms, I recall a recent thread/discussion that indicated LTFT aren't really a representation of WOT performance since it ain't in closed loop at WOT - when an SL55 pump would really count.??
b22b
Old May 27, 2014 | 06:48 PM
meh03's Avatar
b22b
LTFT was about 4. WOT is where it's important and I haven't tried that yet. Unfortunately I don't have a wide band sensor. I'll have it re-tuned as well after I install the big manis. I'm only running the 65mm pulley so I'm thinking it will work well. Hopefully.
Old May 27, 2014 | 09:08 PM
So you stayed with a stock SRT6 regulated filter??
Old May 28, 2014 | 10:02 AM
meh03's Avatar
Correct. I did not want to go the separate in-line regulator route.
Old May 28, 2014 | 01:04 PM
Therefore your fuel pressure will always be regulated by the filter at the preset range of 54-58 PSI (these figures have been mentioned here on the forum). I'm not sure what you have gained by installing the SL55 pump other than a more constant fuel pressure at WOT?
Even with the SL55 pump with OEM filter my fuel was dropping off sharply at 5600rpm until I installed the AFPR. Then I still needed to increase the pressure up to 68PSI to solve my lean issues.
Old May 28, 2014 | 03:32 PM
meh03's Avatar
This is my understanding from the many posts on the subject. You are running a 62mm pulley where as I am running a 65mm. Others have said the extra constant pressure will solve problems with the 65. If I were to go smaller then I would need to change the regulator. At least that's what I read and am hoping it works.
Old May 28, 2014 | 06:38 PM
Roncombs25701's Avatar
Has anyone thought about or have used a fmu system to help the air to fuel ratio here a pic and details I've been thinking About it any thoughts ? image.jpg
Old May 28, 2014 | 06:39 PM
Here's a pic of the unit image.jpg am debating about using this if I go smaller or stacked I'm only running the EC 65mm pulley but hey might be useful for any pulley set up
Old May 28, 2014 | 08:17 PM
My understanding is that with the 65mm you really don't need any fuel upgrades. Since you have added the SL55 pump, I'm questioning whether you would see any benefits since the filter is still regulated at the factory setting?? In essence you have added a pump capable of higher flow but you are still restricting the flow due to the stock filter. Have you really changed anything?
Old May 29, 2014 | 05:36 PM
  #38 (permalink)
meh03's Avatar
There has been a lot of discussion on this. Some have said it solved their lean problems with the idea that it will not fall off in the upper rpm range and will maintain constant pressure. Some have also said it has the ability to flow more volume at the same pressure as the stock pump but I don't know about that.
Old May 29, 2014 | 05:42 PM
  #39 (permalink)
Billy22Bob's Avatar
It makes sense that if the stock pump is dropping pressure at WOT, the OEM pressure regulator will be wide open to try to achieve its goal, but the pump ain't up to it (reportedly)....and your fuel supply (pressure) will start to drop - maybe only a few psi and maybe only at WOT - but enough to affect AFR.
Putting the bigger pump in would maintain the line pressure better and the OEM pressure regulator might not need to be wide open any more t achieve its set point....
my2c
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
