Mityvac substitute for those interested
Old Nov 2, 2014 | 03:30 PM
Codyktt's Avatar
Lightbulb Mityvac substitute for those interested
Decided to change out my supercharger oil, and the traditional methods of a syringe/raising the car wasn't working great for me, decided to make a quick liquid vacuum. Pretty simple to do, I haven't seen this idea on the forums yet. Figured it might help some people out.
Required items:
  • 1/4" tubing - Aquarium air tubes can be purchased at Walmart
  • Plastic bottle of favorite drink (Preferably thicker plastic)
  • Standard household/shop vacuum with hose attachment
  • Heat source and metal object to make small hole in said plastic bottle
Insert the vacuum into the top of the container, seal it however you deem necessary, make the small hole near the top of the bottle and run the tube down towards the bottom. The other end of the tube goes into the supercharger oil outlet. Turn the vacuum on and off to prevent the bottle from completely crushing. You just want negative pressure inside. Move the tube further back as it stops collecting as much oil.
-Cody
Old Nov 2, 2014 | 03:50 PM
texas t's Avatar
Talking Re: Mityvac substitute for those interested
Sounds like a great way to perform task, will keep this in mined, Thank you,
Old Nov 2, 2014 | 03:55 PM
austinbarrylee's Avatar
Default Re: Mityvac substitute for those interested
how often you are suppose to change supercharger oil
Old Nov 2, 2014 | 04:06 PM
syfi's Avatar
Check out this pdf file and you'll see why anytimes a good time.
https://www.crossfireforum.org/forum...oil-change.pdf
And here's what I use for small oil changes on my mower, Motorcycle, rear diff or supercharger. Under $40!
http://www.liquivac.com/
File Type: png
Old Nov 3, 2014 | 02:09 AM
Billy22Bob's Avatar
what a great little thinker!....
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Billy22Bob
Oct 1, 2015 05:34 AM
Oct 1, 2015 01:42 AM
xfireon20z
Sep 10, 2015 04:27 PM
PA/XFIRE
Sep 5, 2015 01:25 PM
