Engine pulleys
Old Jan 14, 2015 | 04:33 PM
tbudlee's Avatar
Default Engine pulleys
Can anyone tell me where I can get a diagram of which engine pulley is called what. I need to replace a couple and cannot tell which ones to get. I have the ability but not the smarts. I have the service manual PDF.but it does not tell that I can find.
Old Jan 14, 2015 | 04:49 PM
DTMenace's Avatar
Default Re: Engine pulleys
tbudlee
Click on the link below, scroll down to link #15 and you will see the diagram of the SRT6 serpentine belt diagram. Using the diagram, you should be able to ID the pulleys in question.
Also look for a sticky listed as SRT6 documentation and it will provide the information as well.
Dennis
DTMenace
https://www.crossfireforum.org/forum...mpartment.html
Old Jan 14, 2015 | 05:10 PM
tbudlee's Avatar
The service manual gives a diagram with numbers, but what I need are the names for each one. Thanks for trying to help a dumb@$$ but I need more.
Old Jan 14, 2015 | 08:39 PM
robby363's Avatar
Is this any help?
Old Jan 14, 2015 | 10:29 PM
Originally Posted by robby363
Is this any help?
He has an SRT not an NA.
Old Jan 14, 2015 | 11:20 PM
robby363's Avatar
Ok thanks I didn't notice it was in the SRT6 section so I replaced it with the SRT.
Old Jan 15, 2015 | 07:00 AM
tbudlee's Avatar
YES,YES,YES Thanks it does help. Got the idler ordered from RockAuto. I did not see the S/C idler but will look again. Replaced the S/C pulley bearing last month.
Old Jan 15, 2015 | 10:05 AM
robby363's Avatar
This is the supercharger idler pulley I ordered from Rock Auto. You have to do a part number( 120 200 04 70) search to find it. The pulley they list under Crossfire for the SRT6 is the same as the n/a so it might be the wrong part.
Old Jan 17, 2015 | 02:53 AM
chuK_138's Avatar
NA cars run a 6-groove belt and pulleys. SRT-6 cars have an 8-groove belt and pulleys. Definitely not interchangeable.
Old Jan 19, 2015 | 01:11 PM
tbudlee's Avatar
You are correct sir! The idler pulley I got from them (Rock Auto) is also only six groove and because the have it listed for the SRT (6 groove) and is to them the correct one according to Chrysler I have to pay to return the wrong part. Why would anyone deal with them?
Old Jan 19, 2015 | 01:36 PM
tbudlee's Avatar
O K got that. Rock Auto did sent a 6 groove idler pulley like the website said it was. I did not notice it was wrong. Sent back. What car do you find the 8 groove like you list above?
Old Jan 19, 2015 | 01:52 PM
Looking at your last two posts I cannot figure out who made the mistake you or Rock Auto.
As a tip you can modify your previous post rather than leave two ambiguous statements for the future readers.
Old Jan 19, 2015 | 08:24 PM
robby363's Avatar
I don't know what car they list it under. I just used the Mercedes part# 120 200 04 70 that was on the supercharger idler pulley and did a part number search and found it.
Old Jan 20, 2015 | 08:38 AM
tbudlee's Avatar
O.K., I can see my statements could be confusing. I ordered the idler pulley from Rock Auto that showed clearly to be only a 6 groove. I did not know at the time I needed an 8 groove pulley. I called to tell them they listed the 6 groove as the correct one for an SRT and the guy said it was correct per Chrysler and therefore I had to pay to send it back. Thanks again Robby363 for your help.
Old Jan 20, 2015 | 09:43 AM
robby363's Avatar
If you need the smooth idler pulley number 8 in the diagram this is the part# 112 202 01 19. I had to replace mine shortly after I replaced the supercharger idler pulley. The cheapest one I could find was this one on ebay. http://www.ebay.com/itm/NEW-Mercedes-SLK32-W203-C32-AMG-Drive-Belt-Idler-Pulley-GENUINE-112-202-01-19-/231162527114?pt=Motors_Car_Truck_Parts_Accessories&hash=item35d25c3d8a&vxp=mtr
Old Jan 20, 2015 | 10:22 AM
That is a beetch of a problem, I can see both sides of the problem, but in all fairness I would think Rock Auto would admit liability and pay just so they do not get a bad name. It is cheaper to keep a customer than to replace him with another, sometimes that policy goes out the door when a buck has to be spent.
I would remind them that on this forum and their Face Book forum, if they have one, a bad comment costs them money and is a blotch on their
reputation.
It is possible that the bearing can be replaced on its own for less than $20.
Old Jan 20, 2015 | 11:32 AM
robby363's Avatar
How would you separate the pulley to get the bearing out? Plus the bearing on mine wasn't the problem. Somehow the area where bearing sits in expanded allowing the bearing slide around in it.
Old Jan 20, 2015 | 05:33 PM
Well, I guess it's not possible. I wasn't sure that's why my answer was phrased the way it was.
That may be a Mercedes part and there are pulleys like that for less than half the cost as they are quite common. You just have to find the correct size.
Old Feb 3, 2015 | 10:02 AM
tbudlee's Avatar
Whatever the cause or trouble I was able to find both idler pulleys at AUTOHAUSAZ. Thanks to robby363. I found them by using 2004 Mercedes SLK32 AMG. Both fit like a charm for $100.
tom2112
Oct 26, 2015 08:18 PM
RiderJC
Oct 5, 2015 06:34 PM
Tp'sfury
Aug 13, 2015 08:20 PM
Jul 29, 2015 06:13 PM
