factory windblocker?
Old May 9, 2020 | 11:47 PM
WD40's Avatar
Default Re: factory windblocker?
Yep, it's totally secure even w/o the bottom bracket! Although it doesn't seem to block a huge amount of wind, does it?
Old May 10, 2020 | 09:45 AM
Yeah, ONLY 2/1000ths of an inch? Hardly a difference is right UNLESS the guy holding the drill wiggles like he11 while holding the running drill! Still, I bet the 'serts' would be real tight! Just do not use a really long drill bit, maybe??? Never can be too careful with what is behind it (as a GENERAL rule).
Having some experience with drilling using hand drills and and drilling machines I doubt that when using a hand drill that the hole ends up the nominal drill size in diameter. Best chances are with a new drill, using a drill that has been hand sharpened all bets are off.
Always work up to the final diameter using smaller drills to start that way you can see if you are still on centre. If you have wandered off centre for some reason you can use a round file to move the hole back on centre and then finish the hole.
There is not much point in having the hole the correct diameter when it is obviously off centre.
syfi
Mar 28, 2026 04:14 PM
blackpepper
Dec 18, 2021 06:17 PM
UNDER PSI
Nov 1, 2015 09:39 PM
livefreeordie
Sep 22, 2015 08:13 PM
Idrenak
Sep 19, 2015 08:17 PM
