Turning the pulley
I am sure he appreciated the thanks anyway.
He just gave you the sizes rather than let some back alley fly by night shop guess at them. Maybe that did not save you any time but it may have saved you big bucks by not trashing your pulley, that's if you passed along the information.
I'm low on meds and still got it. I sent my pulley out today and will post the results when I get the parts i have accumulated on the car. I decided to go with a stacked set-up of 178/70. Pulley saver kit also. This set-up will allow me to use the stock injectors. I bought an SL55 fuel pump off ebay for $80. shipped. I will be getting Rob's free flowing filter and adjustable regulator. A wideband and oil separator will be going on also. I did not want to push the SC much past the recommended 15,000rpm max even though it is only over 15k past 5500 engine rpm. the hassle of injectors and the tune for them steered me towards the 70mm pulley. I'll go with the ported lower "Y" pipe and "tweaked" intakes to make the difference in power. These cars/motors seem to max out in the high 11's so why push it? For those who do I say more power to them and they are the pioneers with the 3.2 Kompressor and that is what Hot rodding is all about, making parts as needed to get that extra tenth.
i always seem to go with the underdog and will not go all out this time as I don't have the health or the extra cash. Anyone know what a "nailhead" motor is? that is where it started for me. Now I have a Mercedes roadster that when complete should run a low 12 and at nearly 115mph, nice
That's fast, but you left something out. Here you go: 1,115 mph. Much better now.
Wideband
178mm/PSK
70mm SC pulley
SL55 fuel pump
Rob's filter & regulator shooting for a 12.2:1
And that darn oil catch can that has been sitting for 6 months
The shop that does my work has a DYNO and I may do a before and after with Jerry doing 2 hours in between. If it, the dyno is open I likely will just to make sure that the 1115 isn't correct
A little off topic, but can someone explain the low end torque gains observed via the "tweaked manis"....
I'm guessing the torque is related to the VE and associate "punch" from the ignition ...at low rpms...
hence the tweaked mani's are offering more air to achieve that punch.
The stock "sloped" mani's would be tuned for a certain volume flow...tapering towards the front as the air gets consumed in the back 1-2 cylinders....
but...at low rpm when the volume intake is less....the sloped mani may preference the rear cylinders...potentially starving the front cylinders...??
With the tweaked mani's - they appear much more uniform and hence may reduce this bias of air towards the back, consequently the front cylinders are seeing more air and hence torque.
Having typed that...I now recall Waldig's bridged manis...
You experienced guys....Let me know if I'm close or way off the mark...
Discussion invited...
Well, I got my stock pulley turned to 70mm by Carr's machine shop as recommended by Jefasold. I paid $90.shipped. I still need a fuel filter and he adjustable regulator. I'll keep it updated. I'll be running a stacked 178/70.
tom2112
Oct 26, 2015 08:18 PM
Jul 17, 2015 07:21 AM
