Crank bolt help!!!
Hey guys I've pulled trigger on installing the 185mm pulley on my 6. Everything is on and ready to be torqued except for one problem.. the new oem crank bolt given to me does not fit the 185mm pulley that I received .. it is wayyyy to short. Ive contacted eurocharged and still waiting for them to chime in but in the mean time anyone here with past experience or with the correct bolt ?
No knowledge here. My 178 came with a new stock bolt. A 185 is foreign to me. I know E/C will be quick in getting you what you need. They always have for me when needed. Best of luck and a quick resolution.
Les
Les
If there is a well there is way... took matters into my own hands..
They are supposed to be replaced after one use, they are tightened in the extreme and they get stretched. You do not want one of these failing on you.
When the instructions say to replace the bolt after one use it is best to repeat that here in case someone reuses the bolt and it fails. Woody had one fail if I recall and the results were not pretty.
My bolt did not fail........WORSE it backed out, so Id use blue locktight....NOT RED thread locker.
The bolt story is that it is stretched and factory recommends new one. I have used bolts again and go 10% above factory torque with thread locker after mine backed out and the pully FLEW off.
Be safe and do what your comfortable with, your responsible..... W
DY
We used the new oem bolt. It was needed to be machined down around the edge for it to fit in the 185 pulley . New custom bolt went in perfect. But as yall said it's for sure a 2 person job. One to torque the bolt and the other to pin the flywheel.. and a bit of muscle. The car now is an absolute beast..
Good news - got there in the end.....probably too late now, but...it would be good to show a pick of where you got in to pin the fly wheel.
MB have apparently got a specific tool for this "locking" job. Good to know how to get away without it.
RED DOG
44
Oct 27, 2020 09:00 PM
CharlieO
Feb 12, 2016 10:55 PM
nonamejane
Oct 17, 2015 06:00 PM
