Another BAS/ESP conundrum
Old Jan 31, 2016 | 10:29 AM
Default Re: Another BAS/ESP conundrum
Originally Posted by Sussudio
"Little push" as in I pushed it as hard as I could towards the clutch plate. It just wasn't seated properly.
I'm curious though as why would the snap ring allow the pulley to retract back to the clutch plate? If that were the case then the bolt would have slack in it no?
The bolt and washer clamp the inner bearing, there has to be some clearance between the outer bearing thickness and the snap ring. I would have guessed it to be about .003/.006" min/max. If it moved that much it could close the gap to spec.
How tight was the bearing in the pulley? If you just pushed it it could not have been too tight.
If you could push on it and get it to move I would have guessed that the magnet would have done it as it is quite strong.
Old Jan 31, 2016 | 10:32 PM
KDW4Him's Avatar
I have an OBD 2 reader but no codes. I'm thinking I'll need something more professional. A friend of mine has a buddy with something that's able to read Mercedes codes, haven't been able to go over to his place yet. I'm going to try ASAP though.
Reading more posts and it seems my pulley and clutch plate seem to have a wider gap between them, more than normal for sure.
OBDII will not read OEM codes.
DRBIII at the dealer is the only way. Some have reported an Autel reader can. But without the exact cause of the code we are only guessing.
lmrzljak
Jun 29, 2016 02:29 PM
gblack32
Nov 6, 2015 06:48 PM
silverbluevt
Nov 1, 2015 10:17 PM
Morphh
Oct 26, 2015 03:03 PM
Morphh
Oct 26, 2015 10:50 AM
