crankcase filters
Old Feb 4, 2016 | 07:51 PM
MichaelHawbaker's Avatar
Default crankcase filters
Cam someone tell me how many filters the crankcase ventilation has and how to replace them? 2006 CF convert.
THanks!! Mike
Old Feb 4, 2016 | 08:01 PM
chuK_138's Avatar
Default Re: crankcase filters
None. You must still be in the old V8 mindset.
Old Feb 4, 2016 | 08:04 PM
I just had it in the shop last week and thats the diagnosis I got
Old Feb 4, 2016 | 08:07 PM
chuK_138's Avatar
I wonder if you're speaking of the charcoal canister now???
Old Feb 4, 2016 | 08:09 PM
no clue.....this is what he told me. Crankcase vents. the filters were clogged. its missing and blows heavy blue smoke under hard throttle. Under normal driving conditions, it doesnt smoke.
Old Feb 5, 2016 | 07:08 AM
There is one big hose that goes from the drivers side vent cover to the intake just before the throttle body, this one is the "pressure normalization" breather.
Then there are 2 smaller hoses, one from each vent cover, that join and go into the intake manifold on the vacuum side of the throttle body. These are the PCV hoses.
All 3 hoses have tiny holes in the vent covers that can get clogged if you ever run any oil that causes carbon and gum buildup ( can we say "Quaker State" here ? )
As long as the engine is fed a regular diet of synthetic oil ( Mobil1 0/40 ), this should not happen.
Old Feb 5, 2016 | 07:38 AM
maxcichon's Avatar
Good answer, A. Good answer.
You even used to know the diameter of those little (
Old Feb 5, 2016 | 08:07 AM
I DO remember the diameters, and I stated them : TINY !
( Actually, the PVC holes are TINY, the other one is merely minuscule )
Old Feb 5, 2016 | 08:29 AM
Is that tiny size metric or inch?
Old Feb 5, 2016 | 08:43 AM
pioneer4x4's Avatar
Whitworth "titchy"
Old Feb 5, 2016 | 08:56 AM
TINY in Alabama is about the size of a mosquito's anus.
MINUSCULE is about the size of a hummingbird's.
Old Feb 6, 2016 | 05:34 PM
thanks a bunch...this is the best answer Ive heard so far on here. Is this a DIY type fix?? I dont really wanna dump $600 for someone else to do this if I can do it.
Old Feb 6, 2016 | 05:36 PM
and btw thats the whole issue...I ran the wrong oil in it and it gummed up everything. I had no clue it would do that...never seen anything like it. It was a mess....now I have thick blue smoke under heavy throttle.
Old Feb 6, 2016 | 06:19 PM
Yes, there's a thread on that DIY :
https://www.crossfireforum.org/forum...over-leak.html
( how to remove and reseal the vent covers, when you have them off you can clean out the holes )
DTMenace
Mar 12, 2016 08:51 PM
user 76087293
Feb 6, 2016 03:16 PM
pop49
Australia
Feb 2, 2016 10:58 PM
Fozz
U.K.
Jan 31, 2016 06:43 PM
Wolf_7
Jan 25, 2016 01:15 PM
