Relocation of the horns with the Needswings DCAI
Old Feb 25, 2016 | 10:49 AM
Scade's Avatar
Default Relocation of the horns with the Needswings DCAI
I ordered the Needswings DCAI with the larger filters that requires the relocation of the horns. Where did you guys relocate them too?
Old Feb 25, 2016 | 10:56 AM
Default Re: Relocation of the horns with the Needswings DCAI
Horns ? I don't see no horns. Maybe you isn't a steer ?
Seriously, you can relocate them to the main frame above, there are already lots of holes in it that you can use, only problem is you will have to extend the wires.
Use soldered, heat shrink connections to do that, just cut the terminal ends off and put the extension between them and the normal wiring.
Welcome to the forum !
Old Feb 25, 2016 | 11:14 AM
I think you can down load the instructions on how to do it from the Needswings site.
Old Feb 25, 2016 | 01:16 PM
NeedsWings's Avatar
here is woody's location that does not require extending the wires
Old Feb 25, 2016 | 03:35 PM
Scade's Avatar
Perfect thanks!
Old Feb 29, 2016 | 09:31 AM
PNA's Avatar
PNA
I didn't relocate mine. I bent the brakets allowing me to keep the horns on the same bracket post and still use the K & N filters with the Needswings DCAI set up. I do have to loosen the left side horn to remove and clean the K & N filter when it's time to clean it but it's a small price to pay to keep the horns up front behind the gill. Not sure if I have a good picture of my set up by I'll try to find one and post later if I can.
Old Feb 29, 2016 | 09:53 AM
chuK_138's Avatar
PNA, the K&N X-Stream filters are massively larger and longer than the standard filters fitted to the intakes. I got them in without replacing the power steering lines but had to mount my horns elsewhere.
Old Feb 29, 2016 | 10:02 AM
PNA's Avatar
PNA
chuk-138
Thanks. Yeah, the X-Streams definitely require relocation. Didn't pay close enough attention to the original post indicating the larger filters.....
Old Feb 29, 2016 | 04:52 PM
JEFASOLD's Avatar
I cut the pipe a little shorter to move the filters outward some then bent the horn brackets and reversed them to bring the horns a bit toward the center.I am also using larger Edelbrock filters. I am thinking of replacing the stock horns with a louder aftermarket pair that are flatter, hence even more room.
user 76087293
Mar 2, 2016 02:43 PM
MichaelHawbaker
Feb 6, 2016 06:19 PM
MichaelHawbaker
Feb 5, 2016 07:32 AM
pop49
Australia
Feb 2, 2016 10:58 PM
Fozz
U.K.
Jan 31, 2016 06:43 PM
