No power off the line
Old Apr 27, 2016 | 08:31 PM
Timesnow's Avatar
Default No power off the line
If I hammer the car at a dead stop it rolls, sits and then takes off. I would like to see it spin the wheels and not put my head forward into the headliner. I've replace the pump with the "10" but I can't impress the crowds, when I try to peel out and hit my head it's embarrassing. Please help
Would a new crank position sensor help.
Old Apr 27, 2016 | 10:03 PM
philosophico's Avatar
Default Re: No power off the line
Something is wrong, peeling out even when stock is easy with this car. You floor it and the tires should break lose with no problem. The lack of power comes from when the IC pump isnt working and the blower it overheated, maybe you didnt put the pump on right?
Even then when you first start the car from a cold start you should have no problem roasting the rear.
Old Apr 27, 2016 | 10:36 PM
chuK_138's Avatar
Did you turn off the traction control first?
Old Apr 28, 2016 | 01:57 AM
Timesnow's Avatar
I believe the IC pump is OK I have good boost at low speeds and at high speeds. Even when the engine is cold and temp out side is in the 50's, no spin. I have not turned off the traction control this is the first time I've heard that.
Old Apr 28, 2016 | 01:59 AM
chuK_138's Avatar
The motor tends to bog if TC is on and you start spinning. It's the trans not wanting to go up a gear without traction, so it stays in gear and drops RPMs. You can't do much of a burnout without turning it off.
Old Apr 28, 2016 | 11:28 AM
NeedsWings's Avatar
the traction control cuts throttle
Old Apr 28, 2016 | 11:59 AM
The way he describes the problem he makes it sound like if he mashes it the gas the car does nothing but roll out slowly then it starts to build acceleration.
Old Apr 28, 2016 | 05:53 PM
Timesnow's Avatar
Well I tuned of the traction control and WOW! I actually peed a little. Thanks guys and or gals (have to be PC).
Old Apr 28, 2016 | 08:44 PM
velociabstract's Avatar
Add a wavetrac and you'll freak out. Just be careful impressing you friends. Watch the Mustang cars and coffee videos if you don't know what I mean.
Les
Old Apr 29, 2016 | 12:33 AM
also do a throttle reset,, use search. it will fix the slow take off ,, just make sure you have lots of clear road in front of you.,,,, jim
Old Apr 30, 2016 | 02:32 PM
Dementors's Avatar
W vs. S setting on the transmission?
Old Apr 30, 2016 | 03:35 PM
Steve Jr's Avatar
W is for winter conditions an starts the car off in second gear.
Old Apr 30, 2016 | 03:56 PM
Yes but that is not the whole story. from the DaimlerChrysler manual 2004 for Mercedes slk 170 series and Chrysler crossfire 170 series W = wet/snow/sand/ and save gas!
even when "W" you floor it the tranny starts off in first gear.
Old Apr 30, 2016 | 11:49 PM
Steve Jr's Avatar
Now....see....this bald spot, is because of you.
XFireCrazy
Nov 28, 2022 06:43 AM
NeedsWings
Nov 18, 2017 11:11 AM
Ned
Apr 29, 2016 05:56 PM
cross4ya
Apr 22, 2016 04:29 AM
mobilefitt
20
Apr 10, 2016 08:02 AM
