Swapped Valeo Alt for Bosch Alt. No Problem?
Old Jun 24, 2016 | 07:59 PM
bdh's Avatar
bdh
Smile Swapped Valeo Alt for Bosch Alt. No Problem?
For anyone who is interested, I have read what a hassle it is to replace a Valeo alternator with a Bosch. Well I just did it & it was super easy. Regardless which alt is better, the Bosch is way cheaper. The main battery power cable fits fine. But I did shim it with 2 x 5/16 flat washers to even out the height. Because of this I was unable to use a lock washer under the nut & used some lock tight instead. The single field wire plug looks exactly the same, but its not. The internal guide ribs are in a slight different position. For this I just kept it simple, by
putting a small flag connector on the pin & filling the area with some silicon. This way it can not fall off, get wet or touch the other pin. I know some people do not want to cut the 1 wire? But for almost double the cost I can live with it. The alt fit & works great.
Should mention this was on my wifes NA. I dont know if you can just do a pulley swap for the SRT or if the shaft is longer?
The alt I bought was a World power Systems 13884A All new not a rebuild. I put my carbon pile & amp clamp on the car. At idle I got 97 amps! Thats pretty good.
Old Jun 24, 2016 | 11:22 PM
Default Re: Swapped Valeo Alt for Bosch Alt. No Problem?
Could you add the Bosch part number so we have a record of it please?
Old Jun 26, 2016 | 01:24 AM
bdh's Avatar
bdh
Edited the org post.
Old Jun 26, 2016 | 10:19 AM
Padgett's Avatar
"The alt I bought was a World Power Systems 13884A All new not a rebuild. "
I have a different World Wide Automotive alternator (CS-144) from a few years ago that is good. World was what used to be Delco-Remy but seems to now be owned by Borg-Warner and is in Pendleton IN which is just south of Anderson where Remy (later Delco Remy) was originally.
This appears to be different from Tom Jennings World Power Systems which is no more.
Can't tell the players without a scorecard.
ps reman Valeo
Old Jun 26, 2016 | 11:05 AM
So it is not a Bosch at all?
Old Jun 30, 2016 | 01:55 AM
bdh's Avatar
bdh
What ever. Its a bosch copy. All I care about is its not a reman & it fits.
Why make something simple hard?
ITS YOUR WALLET!
Old Jun 30, 2016 | 07:32 AM
You had to modify the electrical connections, what could have been simpler that the correct part? Let us know if this brand of alternator is better than the Valeo or Bosch parts.
Glad you have it solved.
I do not think that it is fair to condem Valeo alternators though, and my chart did show the numbers of the Bosch alternatives. I personally would have no problem fitting a Valeo, in all the time I have spent on this forum I cannot say that Valeo has shown up as a poor performer. I am sure that had it been so it would not continue to be a OEM supplier.
cziggy
Aug 12, 2023 06:33 PM
bbsrt6
Jul 26, 2016 04:28 PM
texas t
May 31, 2016 05:05 PM
BluBird
May 5, 2016 09:09 AM
Ned
Apr 29, 2016 05:56 PM
