Lack of Power, Not Intercooler Pump
Old 02-08-2017, 10:17 PM
Robert Andrew's Avatar
Default Re: Lack of Power, Not Intercooler Pump
I would look into the brake light issue. I know hitting to brake while driving will cut the throttle.
I solved that one. The emergency brake switch had gotten knocked out when I stripped the interior. Thanks.
Old 02-08-2017, 10:18 PM
Originally Posted by philosophico
Could be the throttle body.
I'm going to swap the accelerator pedal, and then the last option is the throttle body. Thanks.
Old 02-09-2017, 07:27 AM
Robert,
the srt well report throttle position thru obd . you should be able to turn it on ,take it for a drive and see if the throttle is opening fully when u floor it . if your foot is to the floor and your obd is showing anything less then 99% the accel pedal is probably the problem . also it well show iat's , if there over 200 degrees your ecm well shut down your supercharger .
Old 04-02-2017, 03:22 PM
05roadsterguy's Avatar
So how did this turn out Robert? At last post you were going to swap throttle pedals, and install a new supercharger.
Old 04-22-2017, 10:10 PM
A new intercooler.
Old 04-22-2017, 11:54 PM
Originally Posted by TheThomaswastaken
A new intercooler.
It was the MAP sensor. Unlike every other car in the world, that you can change the MAP sensor on in 5 minutes. The SRT6 requires you to remove the supercharger and intercooler.
Old 04-23-2017, 09:01 AM
So, it's fixed now? How much time or money did it cost to fix? How'd you determine it wa the MAP?
Old 04-23-2017, 09:29 PM
It took forever. I figured it out through the process of elimination. I tried all of the easy fixes first. I'll have it on the racetrack in a couple of weeks, and I'll know for sure if it's fixed.
Old 04-23-2017, 09:32 PM
I have two other SRT6s, so I took the accelerator pedal off of another one and eliminated that. I checked all of the connectors. Checked codes several times, and no pertinent codes. I just kept looking until we found it.
Old 04-23-2017, 09:35 PM
I do my own work, so it cost me 40 hours, a lot of aggravation, and $200.00 +/- in parts. I also changed the cam position sensor, the crank position sensor, and the MAP sensor, so I don't have any other issues.
