Replacing skreem and ring
Old Mar 18, 2017 | 05:10 PM
fastfred's Avatar
Default Replacing skreem and ring
So as most know I have the 3 Stricks and your out problem so car motor turns over but does not run ...I was able to get to the skreem box behind dash without pulling the whole thing out I just removers the screws from the dash and slid it a side without removing all the cables and like exposing the box and ring...
Old Mar 18, 2017 | 05:13 PM
fastfred's Avatar
Default Re: Replaceing skreem and ring
It was easy to reach in and unplug box and take it out ...
Old Mar 18, 2017 | 05:19 PM
fastfred's Avatar
Now have to wait for the ups to get here to get new skreem box and ring to reinstall ....and put back together so far 2 hours to take a part and that's only because I'm a very slow old man ... hahaha
Old Mar 18, 2017 | 05:26 PM
Sounds a lot easier. How many screws and which ones? Maybe you could take pics when reassembling?
Old Mar 26, 2017 | 02:51 PM
fastfred's Avatar
Oh- no got my skreem and ring in the mail last night too dark to see so today I have been reinstalling and putting dash back and I'm almost done and I look down on the floor board and see a 11/2" spring laying there and I did not take any springs off when taking apart has anyone seen this spring under dash before I have been looking around under there for over 2 hours and can't find where it goes ??? Any help please ???
Old Mar 26, 2017 | 03:09 PM
Probably goes to the column in/out slide locky thingey.
Nice clean carpet ( ͡° ͜ʖ ͡°)
Part #20 maybe ?
Old Mar 26, 2017 | 03:53 PM
fastfred's Avatar
Part #20 maybe ?
YES that has to be it .... THANK YOU AGAIN you do know your stuff ...
Old Mar 26, 2017 | 03:56 PM
fastfred's Avatar
It that spring have to be used I hate to pull this all apert again ??? From the picture I can't tell what it's holding together??
Old Mar 26, 2017 | 04:09 PM
fastfred's Avatar
I'm done putting back together but now key will not unlock or lock or anything battery is good ...
Old Mar 26, 2017 | 04:42 PM
That is a sign that spring is finally here. Sorry.
By the way that is a seat top, real genuine Corinthian suede.
Old Mar 26, 2017 | 05:54 PM
fastfred's Avatar
That's funny stuff ... but key will not work went to the store and bought new batteries fob light blinks red seems to work but not on car will. It not unlock or lock doors can't turn the key in any way .... do I have in some way re do my fob to new skreem???
Old Mar 26, 2017 | 06:15 PM
The fob batteries have nothing to do with the car starting, they just operate the remote door unlocking/locking.
The fob may have to be reset if the batteries were out too long or dead too long, try a fob reset anyway.
Did you try to jiggle the steering wheel left to right/right to left while trying to turn the key?
Did you find where the spring went?
Old Mar 26, 2017 | 06:21 PM
fastfred's Avatar
I tried a reset where I pushed the unlock button 2 times and within 30 sec. try to turn key red light did blink but key will not turn?? Is there another way to reset fob?
Old Mar 26, 2017 | 06:45 PM
fastfred's Avatar
Well I'm taking the dash apart again and make sure the skreem is hooked up right...
Old Mar 26, 2017 | 06:58 PM
fastfred's Avatar
Well spring #20 is in place so that's not where the spring came from .... at this point I'm pulling my new skreem out putting in my old one and see if key will turn and doors maybe lock that will tell me if that's the problem?
Old Mar 26, 2017 | 07:07 PM
fastfred's Avatar
So I have a BAD SKEEM I hooked up my old one and fob works fine and key now turns on fine ....all that work ��....have to call rob at needswings and see what's up??????
Old Mar 26, 2017 | 07:50 PM
The SKREEM does not determine if the key turns or not. I would suggest that you have put something back correctly this time that you did not do the previous time.
I believe that when the key is pushed fully a lock that prevents turning the key and the steering wheel lock is unlocked. Perhaps you did not connect that mechanism correctly. It is underneath the ignition switch and can be seen in the Sticky Key Fix. CLICK
Old Mar 26, 2017 | 08:03 PM
fastfred's Avatar
Well you could be right as most of the time you are but I did use the sticky write up to help me take things down to that point ... agin not sure what is going on I had my son (he's 40 ) come over and help this old man and take a look and he did same as I did and with my old skreem fobs work and with the new one they don't we don't get why but we both had the same things happen so till I talk to rob to see what's up ???
Old Mar 26, 2017 | 08:12 PM
fastfred's Avatar
Oh and the 2nd 3rd and 4th times we changed out the skreem we did NOT put any thing back together just plugged in the skreem and tried fobs with dash apart as it is now still apart...
Old Mar 27, 2017 | 09:46 PM
fastfred's Avatar
Thank you Rob at neeswings he made it so easy for me to progam.... car works fine now it was all on me it not working right ...and putting it back together was easy only took me about 30 mins or so .....so all you out there where right it was the skreem... thank you all for the help..
