Installed a teamrxp catch can today!
Old Apr 14, 2017 | 07:29 PM
TeamRXP's Avatar
Default Installed a teamrxp catch can today!
took less than two hours and always evacuates..best catch cans out there hands down
Old Apr 14, 2017 | 07:47 PM
Default Re: Installed a teamrxp catch can today!
Looks like it makes getting at the dip stick awkward.
The hose runs are long and you could get oil condensing it them, and long runs reduce efficiency.
You have to drill a hole for the bracket.
Other than that it looks really good and professional.
Old Apr 14, 2017 | 08:06 PM
TeamRXP's Avatar
looks like it makes getting at the dip stick awkward.
dip stick comes out fine... 1/4 turn drain valve with clear hose drains to bottom of car so you just put a cup underneath. Long runs do not reduce efficiency as these are 1/2" i.d. Lines and move a lot of volume. That's what you want... We catch 95% of contaminants..( plus the only "dirty" line is the center line, the outside lines are vacuum alternating signals. One is manifold vacuum and the other is port side vacuum (atmosphere side of the throttle body)
we are pulling vapors from the engine through the center line on the can only. The 'coalescing" takes place in the first chamber where the vapors solidify. These are 1/2 inch lines and longer runs are fine... The vacuum signal is very strong with over 20" at idle.
Thanks
