Rear Differential plug size
Old Apr 19, 2017 | 05:58 PM
pjs626's Avatar
Default Rear Differential plug size
I want to change the rear diff fluid. I have looked everywhere but in the right place. I can not find what size torx bit do I need for the fill plug. I have a T55 and it looks 2 sizes larger(T70) This would save me a lot of time knowing so.
Old Apr 19, 2017 | 06:05 PM
Default Re: Rear Differential plug size
According to chuk_138 :
Two plugs, 14mm hex. Fill plug is on the driver's side, drain on passenger. Takes about 1.6 liters. Just have it on a level surface when refilling it, all the way to the fill plug opening.
You can Amazon it :
Amazon Amazon
Old Apr 19, 2017 | 06:40 PM
pjs626's Avatar
It is not a hex, This is an SRT6 and I looked and they are torx
Old Apr 19, 2017 | 07:04 PM
OK, then Chuk must be wrong.
Old Apr 20, 2017 | 08:29 AM
maxcichon's Avatar
Different punkins?
Hmmmm.....
Old Apr 20, 2017 | 08:50 AM
Buggin's Avatar
The rear cover is reverse torx, but both my fill and drain plugs are the normal big hex...
Old Apr 20, 2017 | 08:53 AM
pjs626's Avatar
The drain is a smaller torx, forgetting what size. The fill is definitely bigger. What do you mean reverse? Are you saying it is a left hand thread?
Old Apr 20, 2017 | 09:24 AM
Could you please post some pictures ?
Everything I have been able to find on MB forums or elsewhere says the plugs are 14 mm HEX, both NA and SRT6.
Old Apr 20, 2017 | 09:52 AM
pjs626's Avatar
I WILL get under the car later. The only possible thought is, I bought the car a year ago. I didn't know a Wave Track Differential had been installed till I saw the sticker next to the differential. I would not understand the plugs being changed from hex to torx.
Old Apr 20, 2017 | 10:20 AM
You can Amazon it :
https://www.amazon.com/Neiko-10074A-...s=14mm+hex+bit
14 mm hex it is as stated in this old thread. CLICK
Old Apr 20, 2017 | 10:25 AM
You can Amazon it :
14 mm (.551) hex it is, as stated in this old thread. CLICK
If you carefully grind .005 off each of the six faces of a 9/16" (.562) hex wrench you can make your own in a pinch.
Old Apr 20, 2017 | 03:47 PM
pjs626's Avatar
You all are correct. It is a 14 hex, it was difficult to see and get a good grab on it with the rust. They are both out and draining. Thanks for the best info out there.
Old Apr 20, 2017 | 05:13 PM
I rekon you'll listen to us next time, you young whippersnapper !
Old Apr 20, 2017 | 07:36 PM
pjs626's Avatar
I was listening, just was not hearing.
Old Apr 20, 2017 | 07:51 PM
Dave, both links don't work (where you have the CLICK).
Old Apr 20, 2017 | 08:15 PM
That is funny because I checked them at the time and they worked. I just did them again, the size is in the Pelican Parts How To.
It is a good job I remembered it was done by harbor or it would have taken ages to find.
Old Apr 21, 2017 | 07:35 AM
maxcichon's Avatar
Yup.
Old farts are quite sensitive, you know?
Old Apr 21, 2017 | 07:38 AM
maxcichon's Avatar
BTW- alaxfire and I found the 14 mm drive (1/2") at NAPA for ~ $8 as I recall.....
Old Apr 21, 2017 | 07:39 AM
maxcichon's Avatar
And I would guess that we don't have to warn you to always remove the filler plug (top) first, right?
Old Apr 21, 2017 | 08:12 AM
harbor's Avatar
I used this kit from Harbor Freight to get the 14mm & 17mm hex heads for the diff & tranny.
Runs $14 and you can get a 20% discount coupon from various publications.
9 Piece 3/8" and 1/2" Drive Metric Hex Bit Socket Set
