2005 Crossfire SRT
Old Jun 8, 2018 | 08:37 PM
Burnley Miller's Avatar
Default 2005 Crossfire SRT
I had my alternator replaced. The mechanic use a 6 groove pulley instead of the 7 groove pulley. It threw the belt and damaged the camshaft position sensor plug. The check engine light comes on. I replaced the plug. The check engine light continues to come on. When I scan for codes it continues to read "camshaft position sensor wiring and is hard to start. When I reset the code it starts fine. How do I reset the code to eliminate the problem?
Old Jun 9, 2018 | 05:19 PM
Steve Jr's Avatar
Default Re: 2005 Crossfire SRT
First make sure your wiring , to the camshaft positioning sensor is correct. Reset the code , then disconnect the battery for 15 minutes. If it still persists , you may need to change the sensor. Please use a Bosch , they fit the connectors better than most aftermarket products...
chrisp92103
Aug 4, 2016 12:14 PM
The359
May 14, 2008 10:46 PM
Miata 5.0
Mar 28, 2008 07:56 PM
vsilvia
Dec 4, 2007 04:01 PM
paulius
Aug 10, 2007 09:37 AM
