front rotors wrong bolt pattern?
Old Jul 16, 2019 | 04:06 PM
unarel32's Avatar
Default front rotors wrong bolt pattern?
2005 SRT6. I ordered stoptech rotors last year and just got around to installing. I have 126.35054SR/SL for the front. These is the correct part number from catalogues I have found online but the bolt pattern is wrong. What gives?
Thanks.
Old Jul 17, 2019 | 01:37 AM
JSK's Avatar
JSK
Default Re: front rotors wrong bolt pattern?
Are you sure you posted the part number correctly? I googled it and got nada.
Old Jul 17, 2019 | 10:48 AM
unarel32's Avatar
Yes that's the number off of the box and my order from rock auto.
I checked needswings here now: NeedsWings Performance Products. PowerSlot slotted brake rotors Front Set and it shows126.35054SL 126.35054SR. Same part number...
Thanks for double checking for me. I guess I'm out $ and time. Hopefully I can locate the right rotors before I REALLY need to change them...
edit.. https://www.apcautotech.com/part-det...odel=crossfire also shows this to be correct part number..
Old Jul 22, 2019 | 05:18 PM
Speedy4x4's Avatar
Are they the same diameter and all measurements?
Does the hub fit?
Or hub and bolt pattern off?
Do they seem like a 5x114.3 instead if a 5x112?
Old Jul 22, 2019 | 06:23 PM
unarel32's Avatar
Yes they do seem slightly larger. Weird thing is the rears have the same part number stamped on them but last two digits are 48 and they have the correct pattern.
Hub fits.
Thanks.
Old Jul 22, 2019 | 10:07 PM
Speedy4x4's Avatar
Could try and talk with where you got them about a exchange?
Worth a shot.
Did you happen to take a pic of it on to see the difference?
Old Jul 24, 2019 | 10:39 PM
unarel32's Avatar
The rotor is stamped 125.35054 HC MIN THK 29.4 MM 158 05/10/16 0072 29019 M12
It appears that it may be 114.3mm.
Rockauto doesn't seem to carry them anymore. I'm trying to see if centric will help.
Old Aug 9, 2019 | 04:35 PM
unarel32's Avatar
So no vendor has been any help and I've thought about my options...
1) Reorder the same rotors and possibly get the wrong ones again. $280
2) wheel spacer/adapters
https://www.amazon.com/Customadeonly-Wheel-Adapters-Spacers-5x114-3/dp/B07CZTQ4GM/ https://www.amazon.com/Customadeonly-Wheel-Adapters-Spacers-5x114-3/dp/B07CZTQ4GM/
$70-80
3) Drill the holes into slots (cheapest but probably a stupid idea).
Any opinions? Thanks guys.
Old Aug 10, 2019 | 01:53 AM
JSK's Avatar
JSK
Are you saying you can’t find rotors to fit? I replaced pads and rotors in June on My SRT Roadster. Rob at Needswings got me EBC slotted rotors and ceramic pads. I can’t tell you part numbers anymore but the rotors came boxed in pairs so you could get fronts only. I think he also sells stop tech. Give him a call. I surely would not use adaptors and definitely would not try to drill them. Brakes are a pretty important component.
Old Aug 10, 2019 | 10:25 AM
2) wheel spacer/adapters https://www.amazon.com/Customadeonly-Wheel-Adapters-Spacers-5x114-3/dp/B07CZTQ4GM/ $70-80
You are correct #3 is a stupid idea.
Old Aug 10, 2019 | 10:33 AM
You want 112 x 5 with a 12mm bolt hole.
Cyril Baldwin
22
Jan 23, 2020 08:09 PM
oldtimer48
Jul 1, 2013 05:05 PM
amick6534
Feb 8, 2008 07:27 PM
JBsZ06
Jul 24, 2005 10:50 PM
