Super charger is making noise
Old May 11, 2020 | 01:01 AM
ChrisA's Avatar
Default Super charger is making noise
At the clutch on the front it is making noise. Local parts changer stated that I will need a new super charger. Anyone have experience with this?
Old May 11, 2020 | 01:10 AM
JSK's Avatar
JSK
Default Re: Super charger is making noise
How many miles? Has the S/C oil ever been changed? If you remove the belt and spin the pulley does the bearing make noise?
Old May 11, 2020 | 09:30 AM
ChrisA's Avatar
200,000. And no it has not been changed. If I spin the black 1/2 inch wide ring on the clutch it makes noise.
Old May 11, 2020 | 10:25 AM
waldig's Avatar
Talking Re: Super charger is making noise
Your moving the bearing, and that is replacable, the bearing has id # on it to find aftermarket, but Rob at Needswings can help you out, Enjoy Woody
Old May 11, 2020 | 10:44 AM
ChrisA's Avatar
Thanks is there a schematic of the clutchpack and super charger
Old May 11, 2020 | 08:52 PM
ChrisA's Avatar
Does anyone have Rob at NeedsWings contact info
This is it
Old May 11, 2020 | 10:51 PM
It's at the bottom of the homepage at needswings.com
Old May 12, 2020 | 08:02 AM
Fla_Xfire_SRT's Avatar
You will probably do well working with Ed at PSE Superchargers if you plan on rebuilding or remanufacturing the supercharger.
Old May 12, 2020 | 09:25 AM
When you rotate the black part you are rotating more than one bearing. So it is best to remove the tension on the belt so that you can isolate the sound to a particular bearing. I would put my money on the bearing in pulley, which is about $50 and easy to change if you do it carefully.
While you have it apart change the oil in the SC.
Old May 12, 2020 | 09:48 AM
ChrisA's Avatar
I’m going to search for the parts breakdown for this so I can understand what all I’m turning. My thoughts it’s the shaft for the turbine itself.
Old May 12, 2020 | 12:06 PM
I could put up pics of the whole SC in pieces but it would be a waste of time if it is the bearing in the pulley.
You have to take the belt off and decide what bearing it is.
It is not a turbine.
Old May 12, 2020 | 12:34 PM
It is amazing how many people ask for help and then do not listen to the answers. It's almost like they want to hear it is the worst possible scenario.
Old May 12, 2020 | 01:30 PM
I guess we have done our part.
Old May 13, 2020 | 09:46 AM
NeedsWings's Avatar
Originally Posted by zeracer
it is amazing how many people ask for help and then do not listen to the answers. It's almost like they want to hear it is the worst possible scenario.
every day
Old May 23, 2020 | 04:58 AM
ChrisA's Avatar
I hear you guys and I do appreciate the help. Just been working 12 hour days since this all started and have not had much time to work on it. I apologize if this all came out sounding wrong.
Old May 23, 2020 | 04:01 PM
ChrisA's Avatar
Trying to get the car to a place this Monday where I can get the belt off. But sadly I’m working 12 hrs all next week. I work in the fast food packageing manufacturing industry and this pandemic is kicking our asses.
sixshooter
Aug 23, 2009 08:59 AM
leflorian
Apr 14, 2009 06:28 PM
Rokypoky
Apr 21, 2008 07:26 PM
Montana Crossfire
Apr 19, 2008 07:17 PM
04Roadster
75
Oct 11, 2006 07:47 PM
